Publishing JointStates in ROS with Gazebo
I am loading a SDF into Gazebo using the gazebo_ros/spawn_model. I am loading a joint_state_controller through the controller_manager and its even publishing a joint_state message. However, there are no joints listed in the joint_state message despite it containing multiple not-fixed joints.
Any ideas how to make the joint_state message include the proper joints?
click to hide/show revision 2
Including gazebo ros control snippet
Edit:
SDF Snippet:
  <robotNamespace>valve</robotNamespace>
