not realistic simulatoin
I am trying to simulate robots using neural networks and genetic algorithms. here is the link to the video.
I don't know why when the two legs being in the air the cube link don't fall down like it should be in real life. even if I put its mass to 100. The gravity is set as default.
I know that the real time factor can affect, but what are other properties that I have to adjust ?
thank you very much !
here is the SDF file :
<?xml version='1.0'?>
<sdf version='1.4'>
<model name="fourlegs">
  <static>false</static>
  <!--**********************body************************************-->
  <link name='corps'>
      <pose>0 0 .04 0 0 0</pose>
        <mass>100</mass>
      <collision name='collision'>
         <size>.1 .1 .02</size>
     <visual name='visual'>
<!--*********************left leg *******************************-->
<link name='jambeDG'>
<pose> .06 .04 .01 0 0 0</pose>
  <mass>10</mass>
      <size>.02 .02 .06</size>
<!--*********************right leg*******************************-->
 <link name='jambeDD'>
  <pose> -.06 .04 .01 0 0 0</pose>
  <mass>10</mass>
<!--**********************JOINTS*********************************-->
<!--**********************joint left leg************************-->
<joint type="revolute" name="jointJambDG">
<pose> -.01 .0 .03 0 0 0</pose>
<child>jambeDG</child>
<parent>corps</parent>
<axis>
  <xyz>1 0 0</xyz>
  </axis>
<!--**********************joint right leg************************-->
<joint type="revolute" name="jointJambDD">
 <pose> .01 .0 .03 0 0 0</pose>
 <child>jambeDD</child>
 <axis>
   <xyz>1 0 0</xyz>
   </axis>
