Installing Gazebo 5.0 along with with Gazebo 2.2 and ROS Indigo (Ubuntu 14.04)
Hi all,
I have ROS Indigo installed with Gazebo 2.2 which comes by default with it. I also want to install Gazebo 5.0 as I want to use its Import feature to import a building floor plan (Building editor) which comes in Gazebo 5.0, I dont have to use Gazebo 5.0 with ROS indigo. When I try the answer here: http://answers.gazebosim.org/question/7999/gazebo5-ros-packages/ it tells me that it will remove ROS Indigo from the machine which I dont want obviously. Is there any way of installing Gazebo 5.0 along with ROS Indigo and Gazebo 2.2?
Thanks in advance. Naman
