To visualize collisional region
Is there a way to visualize collision (box, cylinder etc.) defined in SDF? If I'm not mistaken, we still need to give Gazebo visual and collision information separately (as found in another thread). So I'm debugging the collisional region by iterating the following steps many times, which is very cumbersome to me.
  1. Edit sdf
  2. Run Gazebo
  3. Run a robot to try hitting the defined but transparent collision region. If it fails to hit, go back to step 1.
User's operation environment: Gazebo 2.2, ROS Indigo on Ubuntu Trusty
Since I'm using ROS, I can use RViz if there's a feature for this. Also for development, upgrading Gazebo can be an option if only higher version software has a functionality.
  1. Edit sdf
  2. Run Gazebo
Since I'm using ROS, I can use RViz if there's a feature for this. Also for development, development purpose, upgrading Gazebo can be an option if only higher version software has a functionality.functionality, but the users will run the resulted files on Gazebo 2.2 (or any version that is compatible with ROS Indigo without tweak).
  1. Edit sdf
  2. Run Gazebo
Since I'm using ROS, I can use RViz if there's a feature for this. Also for development purpose, upgrading Gazebo can be an option if only higher version software has a functionality, but the users will run the resulted files on Gazebo 2.2 (or any version that is compatible with ROS Indigo without tweak). tweak).
