Meaning of visibility Flags
asked 2015-10-13 07:00:45 -0600
NikolasE gravatar image
updated 2015-10-13 07:49:14 -0600
Hello!
I'd like to see the endpoints of laserscanner in a camera to simulate a line laser attached to my robot. The laser is however only visible in the gazebo-GUI, but not in a simulated camera image.
I had a look around and found the LaserVisual.cc ( https://bitbucket.org/osrf/gazebo/src/439c127c6f494d8208b082c8832610ea2f67ce8c/gazebo/rendering/LaserVisual.cc?at=default&fileviewer=file-view-default ) which looks as if it is responsible for drawing the visualization of the laser scan.
My main finding was this line
this->SetVisibilityFlags(GZ_VISIBILITY_GUI);
that looks as if it is used to select who can see this visualization. Before I start to recompile the whole gazebo, I'd like to ask if it would be enough to set this flag to GZ_VISIBILITY_ALL to get the cameras to see the laser visualization.
answered 2015-10-13 07:42:15 -0600
chapulina gravatar image
The short answer is that should work. For a reference, this is the visibility mask for cameras:
this->viewport->setVisibilityMask(GZ_VISIBILITY_ALL &
    ~(GZ_VISIBILITY_GUI | GZ_VISIBILITY_SELECTABLE));
You could also try to change the visibility mask of your camera instead of the flags for the visual.
Thanks! Is it possible to change the mask of the camera or the laser via parameters? Or do I really have to create my own plugin?
NikolasE gravatar imageNikolasE ( 2015-10-13 07:48:07 -0600 )edit
I think you'll need to create a plugin.
chapulina gravatar imagechapulina ( 2015-10-13 16:53:05 -0600 )edit
Asked: 2015-10-13 07:00:45 -0600
Seen: 730 times
Last updated: Oct 13 '15
