gazebo bumper plugin wont give me any data ?
I'm working on nao simulation in gazebo when i call "rostopic echo /nao_robot/fsr" on terminal it gives me a lot of these
header:
  seq: 49
  stamp:
    secs: 0
    nsecs: 0
  frame_id: RFsrRL_frame
states: []
but it actually doesent give me any numbers
while the gztopic gives me a lot of params and numbers
  contact {
  collision1: "nao_v40::r_ankle::r_ankle_collision_RFsrFL_frame"
  collision2: "ground_plane::link::collision"
  position {
    x: -0.42475
    y: 0.9781
    z: -0.00050999999999996664
  position {
    x: -0.42475
    y: 0.9681
  position {
    x: -0.43475
    y: 0.9781
  position {
    x: -0.43475
    y: 0.9681
  normal {
    x: 0
    y: 0
    z: 1
  normal {
    x: 0
    y: 0
    z: 1
  normal {
    x: 0
    y: 0
    z: 1
  normal {
    x: 0
    y: 0
    z: 1
  depth: 0.00050999999999996664
  wrench {
    body_1_name: "nao_v40::r_ankle::r_ankle_collision_RFsrFL_frame"
    body_1_id: 281
    body_2_name: "ground_plane::link::collision"
    body_2_id: 5
    body_1_wrench {
      force {
        x: 0.072087592596782241
        y: 0.028411028459002015
        z: 3.2030964913988988
      torque {
        x: 0.10100978879127898
        y: -0.160708389002122
        z: -0.000847823940497985
    body_2_wrench {
      force {
        x: 0
        y: 0
        z: 3.6714702680842885e+228
      torque {
        x: 2.4711723928230347e-259
        y: 9.3035059818977424e+199
        z: 5.6052338313193757e-67
  wrench {
    body_1_id: 281
    body_2_id: 5
    body_1_wrench {
      force {
        x: 0
        y: 0
        z: 0
      torque {
        x: 0
        y: 0
        z: 0
    body_2_wrench {
      force {
        x: 3.8628231006005092e+174
        y: 9.7782040937894567e+199
        z: 1.5513041645708511e+218
      torque {
        x: 8.0750745817655192e-13
        y: 5.0510556981628804e-85
        z: 5.5510021959412005e+180
  wrench {
    body_1_id: 281
    body_2_id: 5
    body_1_wrench {
      force {
        x: 0
        y: 0
        z: 0
      torque {
        x: 0
        y: 0
        z: 0
    body_2_wrench {
      force {
        x: 1.1892206589683481e+93
        y: 6.1850557490740837e+223
        z: 4.37073153235929e-19
      torque {
        x: 5.8310458343477418e+252
        y: 1.1505135141515544e+248
        z: 3.6718864393444843e+257
  wrench {
    body_1_id: 281
    body_2_id: 5
    body_1_wrench {
      force {
        x: 0
        y: 0
        z: 0
      torque {
        x: 0
        y: 0
        z: 0
    body_2_wrench {
      force {
        x: 1.0854901422561223e+189
        y: 3.6351494492871948e+228
        z: 3.6344582440600231e+228
      torque {
        x: 2.1797885502573651e+243
        y: 4.7019837676989491e+198
        z: 2.9313226905821438e+256
  time {
    sec: 0
    nsec: 1000000
  world: "default"
where i'm going wrong ? my definitions are like this :
<gazebo reference="RFsrRL_frame">
    <mu1>0.5</mu1>
    <mu2>0.5</mu2>
    <selfCollide>false</
    <turnGravityOff>false</
    <fdir1>1 0 0</fdir1>
    <maxVel>0.1</maxVel>
    <minDepth>0.003</minDepth>
    <sensor name="RFsrRL" type="contact">
      <update_rate>20</update_rate>
      <visualize>false</visualize>
      <contact>
        <collision>RFsrRL_frame_
      <!--  <topic>RFsrRL</topic>-->
      </contact>
   <plugin name="gazebo_ros_bumper_ controller" filename="libgazebo_ros_bumper.so">
        <robotNamespace>nao_robot</robotNamespace>
      <alwaysOn>true</alwaysOn>
    <updateRate>20</updateRate>
    <bumperTopicName>fsr</bumperTopicName>
    <frameName>RFsrRL_frame</frameName>
do i need to add more parameters to plugin section ? or its not even suppose to show anything other than they are already showing ?
Asked by soshiant1992 on 2015-11-10 23:29:17 UTC
Did you solve this problem? I'm seeing the exact issue with Kinetic Gazebo 7. I tried adding "_collision" tags in the urdf, to no avail.
Asked by dcconner on 2017-03-07 19:52:31 UTC
Does the gz topic contain contacts for the Frame you specified?
The plugin only effects the links you specify
BTW. your URDF part seems broken (contains multiple incomplete lines...)
Asked by evilBiber on 2015-11-11 07:16:44 UTC
i don't know why but URDF was just a copy paste problem i mean it is correct on my PC gztopic had also this problem i think this edit will clarify.
Asked by soshiant1992 on 2015-11-11 08:42:56 UTC
