Failed to load plugin undefined symbol
Hi, I'm new at gazebo/ROS and wanted to write my own plugin after i tried the tutorial. but i get the following error:
 Error [Plugin.hh:156] Failed to load plugin /home/student/gazebo_plugin_tutorial/build/libTestPlugin.so: /home/student/gazebo_plugin_tutorial/build/libTestPlugin.so: undefined symbol: _ZN6gazebo10TestPlugin4InitEv
This is my CMakelist.
  cmake_minimum_required(VERSION 2.8 FATAL_ERROR)
find_package(Boost REQUIRED COMPONENTS system)
include_directories(${Boost_INCLUDE_DIRS})
link_directories(${Boost_LIBRARY_DIRS})
include (FindPkgConfig)
if (PKG_CONFIG_FOUND)
  pkg_check_modules(GAZEBO gazebo)
endif()
include_directories(${GAZEBO_INCLUDE_DIRS})
link_directories(${GAZEBO_LIBRARY_DIRS})
add_library(TestPlugin SHARED TestPlugin.cc)
target_link_libraries(  TestPlugin ${GAZEBO_LIBRARIES} ${Boost_LIBRARIES} ${catkin_LIBRARIES} )
Thanks in advance for every answer
Asked by gazbegin on 2015-11-26 15:50:28 UTC
Hi there,
the error appears because the plugin was not correctly linked. You probably missing a link_directories variable.
I would just start with the given working plugins from the tutorials, and grow from there. Here is the link: http://gazebosim.org/tutorials?tut=plugins_hello_world
Cheers, Andrei
Asked by AndreiHaidu on 2015-11-26 16:37:37 UTC
Thanks for the fast answer.
Yeah I already did those tutorials from there and they are working fine. So the difference in the plugins is that I want to use the plugin with a publisher and subscriber.
Asked by gazbegin on 2015-11-26 17:47:28 UTC
ros or gazebo publisher/subscriber?
Asked by AndreiHaidu on 2015-11-27 04:16:07 UTC
I want to publish velocity, angle in ros. Subscribe it in the gazebo plugin. And publish the actuell velocity, position etc from gazebo to ros
Asked by gazbegin on 2015-11-27 04:38:37 UTC
did you look over the gazebo-ros tutorials, there are many working examples and explanations there http://gazebosim.org/tutorials?cat=connect_ros
Asked by AndreiHaidu on 2015-11-27 05:23:24 UTC
in my case I was doing an extension of a plugin (the FlashLightPlugin) and I did not link mine with that.
adding the following on my CMakeLists.txt and recompiling resolved the issue.
target_link_libraries(flash_light_extension_plugin ${GAZEBO_LIBRARIES} FlashLightPlugin)
Asked by lauracorssac on 2022-01-28 11:15:11 UTC
