Perform one simulation step
asked 2015-12-07 06:56:03 -0500
Georacer gravatar image
Hello everyone!
I'm want to interface ROS and Gazebo to perform a robot control task.
However, I want to have full control of the simulation evolution, by arbitrating the simulation steps. To be more specific, I publish a simulation clock in ROS and then: I want to tell Gazebo to execute the next simulation step, gather data, perform calculations over them and publish control outputs for the next simulation steps. Afterwards, run the next simulation step and start over.
I found this question, but it is outdated and with broken links.
Is there anything more recent on this topic?
Thanks, George
answered 2015-12-07 09:39:40 -0500
AndreiHaidu gravatar image
Hi there,
as @scpeters mentioned in the other question you could publish gazebo world_control messages on the ~/world_control topic. You start the simulation paused and you send a message with step = true to step once in the simulation.
Cheers, Andrei
answered 2015-12-07 10:33:54 -0500
@AdreiHaidu
(Posting a separate answer because of space restrictions)
I am using ROS Indigo. I have done sudo apt-get install ros-indigo-gazebo-ros-pkgs.
I can successfully launch Gazebo with roscore && rosrun gazebo_ros gazebo.
A rostopic list returns (as expected from here)
george@csl-laptop:~$ rostopic list
/clock
/gazebo/link_states
/gazebo/model_states
/gazebo/parameter_descriptions
/gazebo/parameter_updates
/gazebo/set_link_state
/gazebo/set_model_state
/rosout
/rosout_agg
Moreover, the available gazeoo ros msgs are only:
george@csl-laptop:~$ rosmsg show gazebo_msgs/
gazebo_msgs/ContactsState       gazebo_msgs/LinkState           gazebo_msgs/ModelState          gazebo_msgs/ODEJointProperties  gazebo_msgs/WorldState
gazebo_msgs/ContactState        gazebo_msgs/LinkStates          gazebo_msgs/ModelStates         gazebo_msgs/ODEPhysics
It seems to me that the world_control message is no longer supported. Am I looking in the wrong place?
Hi, (you can edit your first answer when you need to add extra information), the topic you are looking for is a gazebo topic, they work pretty similarly to ros topics. So try the command ` gz topic -l ` to view the topics. To test the sent messages you can `echo` the topic and then pause/play/step into the simulation from the GUI to see the relevant messages.
AndreiHaidu gravatar imageAndreiHaidu ( 2015-12-07 13:29:57 -0500 )edit
I hadn't realized that Gazebo has its own set of topics, subscribers and publishers. Thanks!
Georacer gravatar imageGeoracer ( 2015-12-07 14:17:20 -0500 )edit
Asked: 2015-12-07 06:56:03 -0500
Seen: 2,291 times
Last updated: Dec 07 '15
