Loading multiple system plugins with Gazebo + ROS
I'm using ROS Indigo with Gazebo. I've created a system plugin for Gazebo that interfaces with ROS. I want to load this system plugin in addition to the the gazeboros system plugin (libgazeborosapiplugin.so). One way that I am able to do this is to pass in the following argument to "emptyworld.launch" in gazeboros:
<arg name="extra_gazebo_args" value="-s libgazebo_ros_api_plugin.so -s libobject_interaction_plugin.so"/> <!--  Load my plugin as a system plugin. Has to be after gazebo_ros plugin -->
Unfortuantely, this creates a single node "/gazebo" from which all the topics from the gazeboros plugin and my plugin are published (which I'd like to avoid). Is there any other way to load a system plugin into gazebo along with the gazeboros plugin?
Asked by Arun on 2015-12-08 23:21:45 UTC
