Robot spawns upside down
When loading a robot model in gazebo from ROS and URDF the robot always spawns upside down and I am unable to figure out why. The URDF is included below:
wheel.urdf:
<?xml version="1.0"?>
<xacro:macro name="juno_wheel" params="wheel_prefix wheel_parent *joint_pose">
<link name="${wheel_prefix}_wheel_link">
<mass value="${wheel_mass}" />
<origin xyz="0 0 0" />
<inertia ixx="0.000175" ixy="0.000000" ixz="0.000110" iyy="0.000000" iyz="0.000000" izz="0.000110" />
<visual>
<mesh filename="package://juno_description/meshes/wheel/wheel.dae"/>
<collision>
<cylinder length="${wheel_radius}" radius="${wheel_width}" />
<gazebo reference="${wheel_prefix}_wheel_link">
<mu1 value="1.0"/>
<mu2 value="1.0"/>
<kp value="10000000.0" />
<kd value="1.0" />
<fdir1 value="1 0 0"/>
<joint name="${wheel_prefix}_wheel" type="continuous">
<parent link="${wheel_parent}"/>
<child link="${wheel_prefix}_wheel_link"/>
<xacro:insert_block name="joint_pose"/>
<axis xyz="1 0 0" rpy="0 0 0" />
<transmission name="${wheel_prefix}_wheel_trans" type="SimpleTransmission">
<actuator name="${wheel_prefix}_wheel_motor">
</actuator>
<joint name="${wheel_prefix}_wheel">
<hardwareInterface>VelocityJointInterface</hardwareInterface>
</transmission>
</xacro:macro>
</robot>
base.urdf
<xacro:include filename="$(find juno_description)/urdf/wheel.urdf.xacro" />
<property name="M_PI" value="3.1415926535897931" />
<!-- Simplified Collision Geometry for the Base -->
<property name="base_size_x" value="1.420"/>
<property name="base_size_y" value="1.620"/>
<property name="base_size_z" value="0.420"/>
<property name="base_mass" value="160.000"/>
<property name="base_height_offset" value="0.200"/>
<!-- Simplified Collusion Geometry for the Wheels -->
<property name="wheel_radius" value="0.31"/>
<property name="wheel_width" value="0.26"/>
<property name="wheel_mass" value="9.000"/>
<!-- Offset for the wheel motors from the root rover frame -->
<property name="caster_offset_x" value="0.5"/>
<property name="caster_offset_y" value="0.2"/>
<property name="caster_offset_z" value="0.00"/>
<!-- wheel offsets -->
<property name="wheel_offset_x" value="0.0"/>
<property name="wheel_offset_y" value="0.0"/>
<property name="wheel_offset_z" value="0.0"/>
<xacro:macro name="juno_base" params="name">
<link name="base_footprint">
<visual>
<box size="0.001 0.001 0.001"/>
<collision>
<link name="base_link">
<visual>
<mesh filename="package://juno_description/meshes/base/base.dae"/>
<link name="inertial_link">
<mass value="${base_mass}"/>
<origin xyz="0 0 0.6"/>
<inertia ixx="0.018276" ixy="0.000041" ixz="0.000065" iyy="0.001884" iyz="-0.000331" izz="0.035991"/>
<joint name="inertial_joint" type="fixed">
<parent link="base_link"/>
<child link="inertial_link"/>
<joint name="${name}_footprint_joint" type="fixed">
<origin xyz="0 0 -0.6" rpy="0 0 0"/>
<child link="base_footprint"/>
<!-- JUNO wheel macros -->
<xacro:juno_wheel wheel_prefix="front_left" wheel_parent="base_link">
<origin xyz="-0.7 0.55 0" rpy="0 0 0" />
</xacro:juno_wheel>
<xacro:juno_wheel wheel_prefix="front_right" wheel_parent="base_link">
<origin xyz="0.7 0.55 0" rpy="0 0 0" />
</xacro:juno_wheel>
<xacro:juno_wheel wheel_prefix="rear_left" wheel_parent="base_link">
<origin xyz="-0.7 -0.45 0" rpy="0 0 0" />
</xacro:juno_wheel>
<xacro:juno_wheel wheel_prefix="rear_right" wheel_parent="base_link">
<origin xyz="0.7 -0.45 0" rpy="0 0 0" />
</xacro:juno_wheel>
</xacro:macro>
</robot>
Asked by badrobit on 2015-12-10 14:18:23 UTC
