Error while launching model in gazebo
I have built an urdf file from solidworks and converted the urdf to sdf as below.
 <?xml version='1.0'?>
<sdf version='1.4'>
  <model name='JMbot1'>
    <link name='Base_plate'>
      <pose>0 0 0 0 -0 0</pose>
        <pose>-0.3317 -0.71959 -0.39019 0 -0 0</pose>
        <mass>0.55378</mass>
          <ixx>0.0061249</ixx>
          <ixy>0.00016086</ixy>
          <ixz>-8.6651e-18</ixz>
          <iyy>0.0041631</iyy>
          <iyz>-1.4656e-17</iyz>
          <izz>0.010283</izz>
      <collision name='Base_plate_collision'>
          <mesh>
            <scale>1 1 1</scale>
            <uri>model://JMbot1/meshes/Base_plate.STL</uri>
          </mesh>
      <visual name='Base_plate_visual'>
          <mesh>
          </mesh>
      <velocity_decay>
        <linear>0</linear>
        <angular>0</angular>
      </velocity_decay>
    <link name='Castor_F'>
      <pose>-0.31952 0.39256 -0.57008 -1.5708 1.1481 -6.76601e-16</pose>
        <pose>2.2204e-16 0 0.031164 0 -0 0</pose>
        <mass>0.056555</mass>
          <ixx>2.4476e-05</ixx>
          <ixy>-2.8588e-35</ixy>
          <ixz>1.0281e-20</ixz>
          <iyy>2.4476e-05</iyy>
          <iyz>-1.2617e-20</iyz>
          <izz>7.4341e-06</izz>
      <collision name='Castor_F_collision'>
          <mesh>
            <uri>model://JMbot1/meshes/Castor_F.STL</uri>
          </mesh>
      <visual name='Castor_F_visual'>
          <mesh>
          </mesh>
      <velocity_decay>
        <linear>0</linear>
      </velocity_decay>
    <joint name='Castor_F' type='revolute'>
      <child>Castor_F</child>
      <parent>Base_plate</parent>
      <axis>
        <xyz>-3.34991e-06 1 -1.50683e-06</xyz>
        <limit>
          <lower>-1e+16</lower>
          <upper>1e+16</upper>
        </limit>
        <dynamics/>
      </axis>
    <link name='Castor_R'>
      <pose>-0.34387 0.39256 -0.86909 1.5708 -0.93144 -3.14159</pose>
        <pose>-1.1102e-16 0 0.031164 0 -0 0</pose>
          <ixz>-3.9352e-20</ixz>
          <iyz>-1.951e-20</iyz>
      <collision name='Castor_R_collision'>
          <mesh>
            <uri>model://JMbot1/meshes/Castor_R.STL</uri>
          </mesh>
      <visual name='Castor_R_visual'>
          <mesh>
          </mesh>
      <velocity_decay>
        <linear>0</linear>
      </velocity_decay>
    <joint name='Castor_R' type='revolute'>
      <child>Castor_R</child>
      <axis>
        <xyz>-1.02941e-05 1 -2.19172e-06</xyz>
        <limit>
        </limit>
        <dynamics/>
      </axis>
    <link name='Wheel_L'>
      <pose>-0.46668 0.40756 -0.70859 2.512 0.081268 3.42872e-15</pose>
        <pose>-0.039049 2.2204e-16 2.498e-15 0 -0 0</pose>
        <mass>0.45064</mass>
          <ixx>0.00091608</ixx>
          <ixy>-9.6693e-19</ixy>
          <ixz>-1.7816e-18</ixz>
          <iyy>0.00053395</iyy>
          <iyz>1.3553e-19</iyz>
          <izz>0.00053395</izz>
      <collision name='Wheel_L_collision'>
          <mesh>
            <uri>model://JMbot1/meshes/Wheel_L.STL</uri>
          </mesh>
      <visual name='Wheel_L_visual'>
          <mesh>
          </mesh>
      <velocity_decay>
        <linear>0</linear>
      </velocity_decay>
    <joint name='Wheel_L' type='revolute'>
      <child>Wheel_L</child>
      <axis>
        <xyz>-0.9967 -3.41567e-15 0.0811786</xyz>
        <limit>
        </limit>
        <dynamics/>
      </axis>
    <link name='Wheel_R'>
      <pose>-0.14688 0.40756 -0.73464 -2.7127 -0.081268 3.14159</pose>
        <pose>0.010951 1.1102e-16 -1.1102e-16 0 -0 0</pose>
          <ixy>-1.2355e-19</ixy>
          <ixz>1.0715e-18</ixz>
          <iyz>-6.7763e-20</iyz>
      <collision name='Wheel_R_collision'>
          <mesh>
            <uri>model://JMbot1/meshes/Wheel_R.STL</uri>
          </mesh>
      <visual name='Wheel_R_visual'>
          <mesh>
          </mesh>
      <velocity_decay>
        <linear>0</linear>
      </velocity_decay>
    <joint name='Wheel_R' type='revolute'>
      <child>Wheel_R</child>
      <axis>
        <xyz>-0.9967 7.32216e-06 0.0811786</xyz>
        <limit>
        </limit>
        <dynamics/>
      </axis>
When i tried to launch the model, i am receiving the below error, how to get around this
Error [ModelDatabase.cc:407] Unable to download model[model://JMbot1/meshes/Base_plate.STL]
Error [SystemPaths.cc:367] File or path does not exist[""]
Error [Visual.cc:2133] No mesh specified
Error [ModelDatabase.cc:407] Unable to download model[model://JMbot1/meshes/Castor_F.STL]
Error [ModelDatabase.cc:407] Unable to download model[model://JMbot1/meshes/Castor_R.STL]
Error [ModelDatabase.cc:407] Unable to download model[model://JMbot1/meshes/Wheel_L.STL]
Error [ModelDatabase.cc:407] Unable to download model[model://JMbot1/meshes/Wheel_R.STL]
Asked by KishoreKumar P on 2015-12-15 14:54:09 UTC
Gazebo is unable to find the "JMbot1" model, which means the directory containing JMBot1 is not in Gazebo's model path (GAZEBO_MODEL_PATH environment variable).
Take a look at this tutorial for more information.
Asked by nkoenig on 2015-12-15 18:01:17 UTC
