projector transformation set in urdf is ignored
Hi, all
I'm trying to use gazebo with PR2 Robot, and I have a trouble with projector.
The pattern is projected behind of the PR2.
image description
Looking into the code deeply, I found that the <pose> tag of the projector in urdf seems to be ignored. https://github.com/PR2/pr2_common/blob/indigo-devel/pr2_description/urdf/sensors/projector_wg6802418.gazebo.xacro#L10
How we can apply projector pose when spawn model on gazebo?
Asked by furushchev on 2015-12-16 01:18:57 UTC
I see you have created an issue for this problem. We'll move the discussion there:
https://bitbucket.org/osrf/gazebo/issues/1807
Asked by nkoenig on 2015-12-16 11:50:50 UTC
OK, I'll write back the solution here when this problem is solved.
Asked by furushchev on 2015-12-22 00:10:47 UTC
