Cannot add material when inserting from a plugin via InsertModelSDF().
asked 2013-02-05 09:27:37 -0600
AndreiHaidu gravatar image
When I insert a model in the environment from a plugin with InsertModelSDF() and I try to give it a material, I get an error.
The code is something like this:
    std::stringstream xml;
    xml << "\t\t\t<visual name='sphere_visual_" << i << "'>\n";
    xml << "\t\t\t\t<geometry>\n";
    xml << "\t\t\t\t\t<sphere>\n";
    xml << "\t\t\t\t\t\t<radius>" << radius << "</radius>\n";
    xml << "\t\t\t\t\t</sphere>\n";
    xml << "\t\t\t\t</geometry>\n";
    //xml << "\t\t\t\t<material/>\n";
    //xml << "\t\t\t\t\t<script>\n";
    //xml << "\t\t\t\t\t\t<uri>file://media/materials/scripts/gazebo.material</uri>\n";
    //xml << "\t\t\t\t\t\t<name>Gazebo/Red</name>\n";
    //xml << "\t\t\t\t\t</script>\n";
    //xml << "\t\t\t\t</material>\n";
    xml << "\t\t\t</visual>\n";
    sdf::SDF sphereSDF;
    sphereSDF.SetFromString(xml.str());
    _parent->InsertModelSDF(sphereSDF);
If I uncomment the <material> tag I get an error and the whole model is not loaded.
Error [World.cc:1383] Unable to find a model, light, or actor in:
<sdf version='1.3'/>
Bug, or am I doing something wrong?
Thanks, Andrei
answered 2013-02-05 11:12:31 -0600
nkoenig gravatar image
I think your SDF is incorrect. Look at the start of your material XML element. It has an forward slash that shouldn't be there:
<material/>
should be
You are right, sorry for not noticing it.
AndreiHaidu gravatar imageAndreiHaidu ( 2013-02-05 16:21:19 -0600 )edit
Asked: 2013-02-05 09:27:37 -0600
Seen: 399 times
Last updated: Feb 05 '13
