Inaccurate Pendulum Period
I'm working on a pendulum model and I'm noticing some inaccuracies when running gazebo with the following world files and pendulum model. What I'm noticing is that the pendulum in the simulation has a wrong period (about a second later than expected). I expect the period to be 2.0071 - my pendulum has a length of 1 as seen in the model file - however after plotting the pose of the ball with respect to time I'm seeing that the period is actually ~2.84.
Currently I'm using ODE as the physics engine however Simbody and Bullet are giving the same results. Any ideas what might be causing this? Thanks!
Oh and I'm using gazebo-6.5.1
Model:
<?xml version='1.0'?>
<sdf version='1.5'>
  <model name='pendulum'>
    <link name='fixedPoint'>
      <pose>0 0 1 0 0 0</pose>
      <gravity>0</gravity>
      <visual name='visual'>
          <sphere>
            <radius>0.01</radius>
          </sphere>
          <lighting>1</lighting>
          <script>
            <name>Gazebo/Grey</name>
          </script>
          <shader type='pixel'/>
          <ambient>0.3 0.3 0.3 1</ambient>
          <diffuse>0.7 0.7 0.7 1</diffuse>
          <specular>0.01 0.01 0.01 1</specular>
          <emissive>0 0 0 1</emissive>
      <collision name='collision'>
        <laser_retro>0</laser_retro>
        <pose>0 0 0 0 -0 0</pose>
          <sphere>
          </sphere>
        <surface>
          <friction>
            <ode>
              <mu>1</mu>
              <mu2>1</mu2>
              <fdir1>0 0 0</fdir1>
              <slip1>0</slip1>
              <slip2>0</slip2>
            </ode>
          </friction>
          <bounce>
            <threshold>1e+06</threshold>
          </bounce>
          <contact>
            <collide_without_contact>0</collide_without_contact>
            <collide_without_contact_bitmask>1</collide_without_contact_bitmask>
            <collide_bitmask>1</collide_bitmask>
            <ode>
              <soft_cfm>0</soft_cfm>
              <soft_erp>0.2</soft_erp>
              <kp>1e+13</kp>
              <kd>1</kd>
              <max_vel>0.01</max_vel>
              <min_depth>0</min_depth>
            </ode>
            <bullet>
              <split_impulse>1</split_impulse>
              <split_impulse_penetration_threshold>-0.01</split_impulse_penetration_threshold>
              <kp>1e+13</kp>
              <kd>1</kd>
            </bullet>
          </contact>
        </surface>
    <link name='ball'>
      <pose>0 0.008999 0.00004 0 0 0</pose>
      <gravity>1</gravity>
          <sphere>
            <radius>0.1</radius>
          </sphere>
          <script>
          </script>
          <sphere>
          </sphere>
        <surface>
          <friction>
            <ode>
              <mu>1</mu>
              <mu2>1</mu2>
              <slip1>0</slip1>
              <slip2>0</slip2>
            </ode>
          </friction>
          <bounce>
          </bounce>
          <contact>
            <ode>
              <kp>1e+13</kp>
              <kd>1</kd>
            </ode>
            <bullet>
              <kp>1e+13</kp>
              <kd>1</kd>
            </bullet>
          </contact>
        </surface>
    <joint name="world_J_fixedPoint" type="fixed">
      <parent>world</parent>
      <child>fixedPoint</child>
    <joint name="fixedPoint_J_ball" type="revolute">
      <parent>ball</parent>
      <pose>0 0 0 0 0 0</pose>
      <axis>
        <xyz>1 0 0</xyz>
        <dynamics>
          <damping>0.000</damping>
          <friction>0.000</friction>
        </dynamics>
      </axis>
    <plugin name="monitorPose" filename="libmonitorPose.so"/>
World:
<?xml version="1.0" ?>
<sdf version="1.4">
  <world name="default">
    <!--<include>-->
      <!--<uri>model://ground_plane</uri>-->
      <!--</include>-->
      <uri>model://sun</uri>
      <uri>model://pendulum</uri>
    <physics type="bullet">
      <max_step_size>0.00001</max_step_size>
      <real_time_update_rate>100000000</real_time_update_rate>
    </physics>
  </world>
EDIT: (12/20/15 22:53 EST)
So after reading this Q&A I got the pendulum to work. I'm guessing physics simulators don't like really small numbers? Has anybody else had issues with this?
Asked by theNerd247 on 2015-12-20 17:30:30 UTC
Can you please share what you did to get "the pendulum to work"? Thanks!
Asked by hsu on 2015-12-21 00:11:25 UTC
What governing equations do you use to find the exact solution? (Your model (as posted) does not have any inertia blocks, hence, mass is 1 kg and MOI is 1 kg m^2, and you'll probably need the equations for compound pendulum to compute the period).
You can refer to the simple pendulum integration test that checks for simple pendulum period correctness.
Asked by hsu on 2015-12-20 23:45:08 UTC
