Gazebo client crashes on startup
I have installed gazebo simulator using the ROS installation (ros-indigo-desktop-full) Gazebo 2.2.3 was installed alongside. When I run
gzserver
The gazebo server connects to master and everything is fine
Gazebo multi-robot simulator, version 2.2.3 Copyright (C) 2012-2014 Open Source Robotics Foundation. Released under the Apache 2 License. http://gazebosim.org
Msg Waiting for master Msg Connected to gazebo master @ http://127.0.0.1:11345 Msg Publicized address: MY.IP.ADDRESS.NUMBER
In a new terminal I run
gzclient
And I get the following error
Error [SelectionBuffer.cc:102] Unable to create selection buffer. Segmentation fault (core dumped)
Couldn't find a solution anywhere. Ideas?
Asked by odedy86 on 2016-01-04 11:08:43 UTC
Hello, I have segmentation fault problems with gazebo, too. Im using archlinux and the update from boost-libs 1.59 to boost-libs 1.60 broke my gazebo setup =(. Although I downgraded back to boost-libs 1.59 the setup is still broken. It seems that my gazebo setup requires boost-libs in version 1.59 and in version 1.60. Has someone the similar problems with gazebo?
Asked by pandoxmon on 2016-01-04 19:13:16 UTC
