How to change the light position in world plugin.
Basically I am using get_scene function. I am getting NULL value in World Plugin. But if i used the same function in System Plugin I am getting proper ScenePtr.
rendering::ScenePtr scene = rendering::get_scene();
Asked by Anshuman on 2016-01-13 15:16:09 UTC
I would try to use this as a start.
Then use physics::WorldPtr _parent .
_parent->GetModel("yourLightModelName")
and with the result of the previous line use : SetLinkWorldPose (const math::Pose &_pose, const LinkPtr &_link)
Asked by Brosseau.F on 2016-01-14 10:00:03 UTC
I tried this but I was getting the NULL as a return value
Asked by Anshuman on 2016-01-14 20:17:53 UTC
That's because lights are not models and currently they cannot be attached to models.
Asked by chapulina on 2016-01-15 01:52:54 UTC
Ok my bad. I thought that light could be model because there is a sun model.
Asked by Brosseau.F on 2016-01-15 02:38:47 UTC
Yeah it can be confusing. It has a model.sdf but no tag. See here: https://bitbucket.org/osrf/gazebo_models/src/9f0a80a06cf3cb41f83183d042274bc3a62bb5b8/sun/model.sdf?at=default&fileviewer=file-view-default
Asked by chapulina on 2016-01-15 02:56:36 UTC
I believe it shouldn't be possible to get a scene pointer form a World plugin because the plugin is in the server and the scene in the client.
On Gazebo versions < 7.0, you could publish a message to the ~/light topic with the new pose. (From Gazebo 7 it's ~/light/modify). Something like this:
auto lightPub = this->dataPtr->node->Advertise<msgs::Light>("~/light");
msgs::Light msg;
msg.set_name(<name>);
msgs::Set(msg.mutable_pose(), <pose>);
lightPub->Publish(msg);
Asked by chapulina on 2016-01-14 12:14:20 UTC
