gazebo is not showing any grid
asked 2016-01-24 10:49:55 -0600
while running gazebo from chroot of ubuntu trusty in ros indigo pkg the gazebo is showing black screen...and is not showing any grid in grey world...please help me to find out what is missing!or what i need to configure or how i can fix this problem ! i am attaching the screenshot! also there are some errors i am getting while running it
Unable to connect to model database using [http://gazebosim.org/models/bookshelf...].
Only locally installed models will be available.
Error [ModelDatabase.cc:387] Unable to get model name[http://gazebosim.org/models/bookshelf] Warning [ModelDatabase.cc:205] Unable to connect to model database using [http://gazebosim.org/models/bowl/mode...]. Only locally installed models will be available.
Error [ModelDatabase.cc:387] Unable to get model name[http://gazebosim.org/models/bowl]
C:\fakepath\Screenshot from 2016-01-23 03-05-11.png
How do you run gazebo ? With "gazebo" command or with "rosrun gazebo_ros gazebo" ?
Brosseau.F gravatar imageBrosseau.F ( 2016-02-01 04:23:30 -0600 )edit
using both commands but results were same!
sumit6887 gravatar imagesumit6887 ( 2016-02-04 00:33:06 -0600 )edit
http://answers.gazebosim.org/question/5971/how-do-you-completely-uninstall-old-versions-of-gazebo/ May be you can watch this link to get the model you want. Have you any internet restriction on your network ?
Brosseau.F gravatar imageBrosseau.F ( 2016-02-12 08:35:34 -0600 )edit
answered 2016-02-12 10:15:57 -0600
nkoenig gravatar image
Do you have internet access?
Asked: 2016-01-24 10:49:55 -0600
Seen: 1,001 times
Last updated: Feb 12 '16
