Gazebo Installation on Windows 7 32 bit
in the tutorial it states that :
In a Windows shell, configure and build Ignition Math
cd ign-math
..\configure
nmake
nmake install
If I input it on windows cmd this happens:
Microsoft Windows [Version 6.1.7601] Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\home>cd ign-math
C:\Users\home\ign-math>mkdir build A subdirectory or file build already exists.
C:\Users\home\ign-math>cd build
C:\Users\home\ign-math\build>..\configure Configuring for build type Debug
C:\Users\home\ign-math\build>cmake -G "NMake Makefiles" -DCMAKEINSTALLPREFIX=" install\Debug" -DCMAKEBUILDTYPE="Debug" -DENABLETESTSCOMPILATION:BOOL=False .. -- The C compiler identification is unknown -- The CXX compiler identification is unknown CMake Error at CMakeLists.txt:9 (project): The CMAKECCOMPILER:
cl
is not a full path and was not found in the PATH.
To use the NMake generator with Visual C++, cmake must be run from a shell that can use the compiler cl from the command line. This environment is unable to invoke the cl compiler. To fix this problem, run cmake from the Visual Studio Command Prompt (vcvarsall.bat).
Tell CMake where to find the compiler by setting either the environment variable "CC" or the CMake cache entry CMAKECCOMPILER to the full path to the compiler, or to the compiler name if it is in the PATH.
CMake Error at CMakeLists.txt:9 (project): The CMAKECXXCOMPILER:
cl
Tell CMake where to find the compiler by setting either the environment variable "CXX" or the CMake cache entry CMAKECXXCOMPILER to the full path to the compiler, or to the compiler name if it is in the PATH.
-- Configuring incomplete, errors occurred! See also "C:/Users/home/ign-math/build/CMakeFiles/CMakeOutput.log". See also "C:/Users/home/ign-math/build/CMakeFiles/CMakeError.log".
C:\Users\home\ign-math\build>nmake 'nmake' is not recognized as an internal or external command, operable program or batch file.
C:\Users\home\ign-math\build>nmake install 'nmake' is not recognized as an internal or external command, operable program or batch file.
C:\Users\home\ign-math\build> C:\Users\home\ign-math\build> C:\Users\home\ign-math\build>
If I input it on it on Git cmd the same thing happens.
What should I do?
Asked by van4lyf on 2016-01-31 23:59:29 UTC
Refer this link http://answers.gazebosim.org/question/12473/widows-7-32-installation-problem/
Asked by Vaidehi on 2016-11-27 01:03:27 UTC
