Headless Gazebo through firewall
I'm trying to run gzserver on a cloud instance running behind a firewall, and access the simulation with gzclient from outside the firewall.
To make a long story short, I've discovered that while I can set GAZEBOIP and GAZEBOMASTER_URI to handle the intial connection, gzserver sends back to gzclient it's IP and some random port(s) for retrieval of additional data.
It's the random additional ports that I'm having trouble with, being behind a firewall. Any idea where in the code I can go to specify a specific port instead of this random mess?
Asked by srees on 2016-02-02 17:06:53 UTC
I know that it's not using GZclient.. but you should be able to write a plugin that communicates on a particular port, and shares the data that is of interest to you.
Asked by SL Remy on 2016-03-03 09:05:54 UTC
Are VPNs an option in your use case?
Asked by SL Remy on 2016-02-07 00:11:05 UTC
No, VPN is not an option for us.
Asked by srees on 2016-02-29 18:04:58 UTC
