boost::lexical_cast<std::string>(port) == "11,345"
asked 2016-02-05 10:11:20 -0600
Mr_Orion gravatar image
boost::lexical_cast<std::string>(port) is a big problem because result of this function depends of locale. And if locale is defined in process, result will be with delimeters, like this ",". And we will have port = "11,345".
answered 2016-02-05 11:07:50 -0600
nkoenig gravatar image
I believe we need to use:
setlocale(LC_NUMERIC, "C");
For reference see this pull request.
Can you try setlocale?
answered 2016-02-08 03:56:37 -0600
Yes I resolved this problem by setlocale. But I changed process locale and it changes behavior of process. Can I change locale to previos, after exiting from client::setup()?
You should be able to get a locale using localeconv(), and then restore this locale after `client::setup`.
nkoenig gravatar imagenkoenig ( 2016-02-08 09:45:58 -0600 )edit
Asked: 2016-02-05 10:11:20 -0600
Seen: 170 times
Last updated: Feb 08 '16
