gz joint and SDF file, "Unable to find joint[robot::knee]"
See This: https://youtu.be/r2DEa_xAeV0
I have a SDF file: model.sdf
With the World file: set_joint.world
And the model plugin: set_joint.cc
I can control the joints from the model plugin but not directly with:
gz joint -m robot -j knee -f 1000
I get from gzserver (running verbose):
[Err] [JointController.cc:289] Unable to find joint[robot::knee]
However if i run
gz model -m robot -j knee -i
I get: model.msg
where i can see that :
joint {
  angle: 0
  type: REVOLUTE
What am i missing?
UPDATE:
I have updated to Gazebo 7 and the joint moves with "gz joint -m robot -j knee -f 1000", but i still get the error "Unable to find joint[robot::knee].." strange that it manages to apply a force to a joint its unable to find ;)
I Uploaded files instead of linking to external source, used model.msg because .txt was not supported.
Asked by maiden on 2016-02-18 05:52:21 UTC
Asked by maiden on 2016-02-19 10:08:21 UTC
The links above are broken. The gz model command applies a force to a model, the joint will move as a side effect.
Asked by nkoenig on 2016-02-19 10:10:35 UTC
Don't put quotes around the names:
gz model -m robot -j knee -f 1000
Asked by nkoenig on 2016-02-19 11:40:38 UTC
ah, that was just a typo in this post. I have fixed that now, I have used 'robot' and as you have written, but with the same result as in the post.. and as seen by " joint[robot::knee]" the gzserver gets the correct path to an existing object but it still generates an error.
Asked by maiden on 2016-02-19 11:47:04 UTC
I loaded your model using gazebo7 and this command causes the knee to move gz model -m robot -j knee -f 1000. Are you sure gazebo is loading the correct model? You might have another "robot" sdf file in a different location that Gazebo is finding.
Asked by nkoenig on 2016-02-19 13:51:56 UTC
Yes but if you run gzserver with verbose, do you get the same error message? I get the error message but the joint moves, i guess its some bug in the gzserver code.. (see the youtube video i added in the top of the question)
Asked by maiden on 2016-02-19 15:18:20 UTC
