gpu_ray sensors bad behaviour when increasing samples
Hello everybody,
I have increaser the samples of a gpu_ray sensors and I have strange laser scan. There is the world :
There is the sensor settings :
<gazebo reference="scan_loc">
<sensor type="gpu_ray" name="scan_loc_sensor">
<pose>0 0 0.0434 0 0 0</pose>
<visualize>false</visualize>
<update_rate>25</update_rate>
<ray>
<scan>
<horizontal>
<resolution>1.0</resolution>
<samples>1080</samples>
<min_angle>-2.35</min_angle>
<max_angle>2.35</max_angle>
</horizontal>
</scan>
<range>
<resolution>0.01</resolution>
<min>0.10</min>
<max>30.0</max>
</range>
<noise>
<type>gaussian</type>
<mean>0.0</mean>
<stddev>0.01</stddev>
</noise>
</ray>
<plugin name="gazebo_ros_head_hokuyo_controller" filename="libgazebo_ros_gpu_laser.so">
<topicName>scan_loc</topicName>
<frameName>/scan_loc</frameName>
And there is the problem:
Why the data seems duplicated ? How the resolution settings is working ?
Update
According to this http://answers.gazebosim.org/question/8221/inaccurate-laser-scan-from-the-hokuyo-sensor-gazebo/ , it could be a display problem.
I am trying to use libgazeboroslaser.so but I get this error :
*** Error in `gzserver': malloc(): memory corruption: 0x0000000003b41670 *** Service call failed: transport error completing service call: unable to receive data from sender, check sender's logs for details Aborted (core dumped)
Update 2
Problem appears when I try to increase the horizontal field of view of the sensor. If I set minangle and maxangle to -1.57 and 1.57, there is no problem. How can I increase the horizontal field of view ?
Thanks in advance.
Asked by Brosseau.F on 2016-02-26 12:05:21 UTC
