GazeboJS - Resetting world state
I have a problem using GazeboJS to reset the world state.
The simple script I am using to test this command is
var gazebojs = require("gazebojs");
var gazebo = new gazebojs.Gazebo();
gazebo.publish("gazebo.msgs.WorldControl", "~/world_control", { reset: { all: true } });
However, this throws an error when running the script in terminal
 >node test.js
terminate called after throwing an instance of 'boost::exception_detail::clone_impl<boost::exception_detail::error_info_injector<boost::lock_error> >'
pure virtual method called
terminate called recursively
Aborted (core dumped)
However by initialising a node and typing each command in the above script into the terminal, it works perfectly. Any ideas or explanations to what I am donig wrongly?
Asked by Lifthrasir on 2016-03-07 14:09:25 UTC
When running the script in the terminal, the script is run and then the node process shuts down. There is a problem during shutdown, because the Gazebo transport seems to die prematurely. This is not a problem when typing into the terminal, because the Gazebo transport is not shutdown in the same way. It is a known problem, but there is no fix yet. Sometimes you can get around this problem by keeping the node process alive for a few seconds after the last message is sent to the simulation server.
Asked by hugomatic on 2016-03-08 13:33:05 UTC
for me it doesn't give an error, but it doesn't either work, doesn't really reset the world.
Asked by MhAyman on 2016-07-01 06:17:55 UTC
