Topic name or index in Subscriber callback
I am creating a model plugin that subscribes to many topics (same name, but only a number changes) and I want all the subscribers to call the same callback. However, if I do that I am not able to identify which subscriber (or topic name) triggered the callback at a given time.
In ROS I saw that it is possible to do this using boost::bind but I cannot make it work in Gazebo, basically because I think the API does not allow it.
Can somebody verify that this is not possible? Or much better, tell me how to identify which subscriber triggers the callback?
EDIT: Posting the code I have tried and corresponding error:
 std::vector<gazebo::transport::SubscriberPtr> _subs;
 size_t n = 10;
 for (size_t i = 0; i < n; ++i) {
    std::stringstream ss;
    ss << "~/ns/base_link/sensor_" << i;
    _subs.emplace_back(
         nh->Subscribe(ss.str(),
         boost::bind(&MyClass::cb, this, _1, i))
And the error (removed verbose data):
error: no matching function for call to gazebo::transport::Node::Subscribe(std::basic_stringstream<char>::__string_type, boost::_bi::bind_t<void, boost::_mfi::mf2<void, MyClass, const boost::shared_ptr<const gazebo::msgs::LaserScanStamped>&, long unsigned int>, boost::_bi::list3<boost::_bi::value<MyClass*>, boost::arg<1>, boost::_bi::value<long unsigned int> > >)
      i)));
note: candidates are:
template<class M, class T> gazebo::transport::SubscriberPtr gazebo::transport::Node::Subscribe(const string&, void           (T::*)(const boost::shared_ptr<const T>&), T*, bool)
   SubscriberPtr Subscribe(const std::string &_topic,
/usr/include/gazebo-5.1/gazebo/transport/Node.hh:175:21: note:   template argument deduction/substitution failed:
 mismatched types void (T::*)(const boost::shared_ptr<const T>&) and boost::_bi::bind_t<void, boost::_mfi::mf2<void, MyClass, const boost::shared_ptr<const gazebo::msgs::LaserScanStamped>&, long unsigned int>, boost::_bi::list3<boost::_bi::value<MyClass*>, boost::arg<1>, boost::_bi::value<long unsigned int> > >
      i)));
I get 4 similar errors, one for each Subscribe overload.
Thanks!
Asked by Javi V on 2016-03-14 11:43:30 UTC
Can you post code that you have tried?
Asked by nkoenig on 2016-03-14 11:46:20 UTC
@nkoenig I've updated the post.
Asked by Javi V on 2016-03-14 11:59:07 UTC
Thanks. I also checked out the code, and it's definitely not possible. You can file an issue for this feature, or try to implement a fix yourself.
Asked by nkoenig on 2016-03-14 12:11:35 UTC
Link to the corresponding ticket: https://bitbucket.org/osrf/gazebo/issues/1875/topic-name-or-index-in-subscriber-callback
Asked by Javi V on 2016-03-14 15:36:33 UTC
