Create joint at runtime via messages
I tried to create a joint that connects the following model
<?xml version='1.0'?>
<sdf version='1.4'>
<model name="my_robot2">
<static>false</static>
<link name='chassis'>
<pose>0 0 .1 0 0 0</pose>
<collision name='collision'>
<size>.4 .2 .1</size>
<visual name='visual'>
<pose>0 0 0.05 0 0 0</pose>
<mesh>
<uri>model://pioneer2dx/meshes/chassis.dae</uri>
<scale>0.9 0.5 0.5</scale>
</mesh>
<collision name='caster_collision'>
<pose>-0.15 0 -0.05 0 0 0</pose>
<sphere>
<radius>.05</radius>
</sphere>
<surface>
<friction>
<ode>
<mu>0</mu>
<mu2>0</mu2>
<slip1>1.0</slip1>
<slip2>1.0</slip2>
</ode>
</friction>
</surface>
<visual name='caster_visual'>
<sphere>
</sphere>
<link name="left_wheel">
<pose>0.1 0.13 0.1 0 1.5707 1.5707</pose>
<cylinder>
<radius>.1</radius>
<length>.05</length>
</cylinder>
<cylinder>
<radius>.1</radius>
</cylinder>
<link name="right_wheel">
<pose>0.1 -0.13 0.1 0 1.5707 1.5707</pose>
<cylinder>
<radius>.1</radius>
</cylinder>
<cylinder>
<radius>.1</radius>
</cylinder>
<joint type="revolute" name="left_wheel_hinge">
<pose>0 0 -0.03 0 0 0</pose>
<child>left_wheel</child>
<parent>chassis</parent>
<axis>
<xyz>0 1 0</xyz>
</axis>
<joint type="revolute" name="right_wheel_hinge">
<pose>0 0 0.03 0 0 0</pose>
<child>right_wheel</child>
<axis>
<xyz>0 1 0</xyz>
</axis>
to a hokuyo (with pose (0.2, 0, 0.2, 0, 0, 0)) by sending a Joint message to /gazebo/default/joint
. I set the following attributes of the message:
name
: "hokuyo_joint"child
: "hokuyo::link"parent
: "my_robot2::chassis"axis1
: xyz set to (0, 0, 1); limitlower, limitupper, limiteffort, limitvelocity, damping, friction set to 0 and useparentmode_frame set to true
After sending the message I tried to move the robot but it moved separately from the hokuyo model. Am I using the correct topic and setting the correct attributes of the message or is it not yet possible to do that with messages?
Asked by gshopov on 2016-03-26 10:13:58 UTC
