i have created my own model and attached a lidar to it i can view the output in the gazebo topic viewerr. But How exactly do i view the output of the lidar in rviz?
i cant seem to view any of the lidar data in rviz tho i can view the image of the outline in the gazebo topic viewer
Asked by Rajnunes on 2016-04-11 02:12:20 UTC
You have to use a gazebo_ros plugin that will publish a topic that you will be able to view in rviz.
A code that I am using (model is in urdf format) :
<link name="safety_lidar_front_left">
<visual>
<cylinder radius="0.0525" length="0.152"/>
<collision>
<mass value="1"/>
<inertia
ixx="0.0025" ixy="0.0" ixz="0.0"
iyy="0.0025" iyz="0.0"
izz="0.0012"/>
<!--Set lidar parameters-->
<gazebo reference="safety_lidar_front_left">
<gravity>0</gravity>
<sensor type="gpu_ray" name="safety_lidar_front_left_sensor">
<pose>0 0 0.036 0 0 0.785</pose>
<update_rate>40</update_rate>
<ray>
<scan>
<horizontal>
<samples>720</samples>
<resolution>1</resolution>
<min_angle>-2.36</min_angle>
<max_angle>2.36</max_angle>
</horizontal>
</scan>
<range>
<min>0.5</min>
<max>50.0</max>
<resolution>0.01</resolution>
</range>
<noise>
<type>gaussian</type>
<mean>0.0</mean>
<stddev>0.01</stddev>
</noise>
</ray>
<plugin name="gazebo_ros_head_hokuyo_controller" filename="libgazebo_ros_gpu_laser.so">
<topicName>scan_front_left</topicName>
<frameName>safety_lidar_front_left</frameName>
Asked by Brosseau.F on 2016-04-11 10:07:10 UTC
is it possible for you to share with me your plugin ..?
Asked by Rajnunes on 2016-04-11 11:02:31 UTC
OMG Never mind Thanks it worked @Brosseau.F :)
Asked by Rajnunes on 2016-04-11 11:16:42 UTC
