gazebo worlds/pioneer2dx.world command not working
EDIT: It eventually loads after about 5 minutes.
I am using gazebo 7.1.0 on Ubuntu 14.04.02.
I did a source installation without changing the default install path.
On following the tutorial http://gazebosim.org/tutorials?tut=quick_start&cat=get_started
I found that $ gazebo worlds/pioneer2dx.world
command does not work on my computer.
The page says world files are located here at /usr/share/gazebo-7/worlds
in an Ubuntu system
but on my computer the worlds folder is located at /usr/local/share/gazebo-7/worlds
Also the shared libraries on my computer are installed at /usr/local/lib/x86_64-linux-gnu
instead of /usr/local/lib
. Although this error was corrected by $ echo '/usr/local/lib/x86_64-linux-gnu' | sudo tee /etc/ld.so.conf.d/gazebo.conf
; $ sudo ldconfig
Asked by arttp2 on 2016-04-17 15:58:21 UTC
Does your edit mean you answered the question? In that case, could you please close it?
Asked by chapulina on 2016-04-19 15:45:34 UTC
