1.4 update resetting the ~/.gazebo/models folder
asked 2013-02-08 13:39:56 -0500
Ben B gravatar image
updated 2013-02-08 13:40:49 -0500
It's possible I've just forgotten where I put the model I was working with a couple weeks ago, but I think it was in the ~/.gazebo/models/ folder.
  1. Would 1.4 have reset the contents of this folder?
  2. If so, is there a way of recovering it?
answered 2013-02-08 17:37:36 -0500
nkoenig gravatar image
It's slightly dangerous to put models that you're working on in the ~/.gazebo/models folder. The danger only comes into play if you happen to give the model that same name as a model currently in the model database, and you download that model from the database. Otherwise, you should be safe.
If the model is not in your .gazebo/models folder, then it's probably someplace else on your computer.
Ah yes. Found it. Silly question. Thanks for the info regarding the ~/.gazebo/models folder.
Ben B gravatar imageBen B ( 2013-02-09 00:17:38 -0500 )edit
Asked: 2013-02-08 13:39:56 -0500
Seen: 134 times
Last updated: Feb 08 '13
