Changing model pose in gzclient by clicking on up/down arrow buttons in properties table does not work
Hello everyone.
When I add a model into the world in gzclient and try to change its pose by clicking on up/down arrows in the Property table (left side of the screen), the model does not change its pose. When I clock on the model directly and drag it around, it works. However, I would like to set a precise pose by entering the values (or by setting them by clicking on the arrow buttons) for each axis.
I am using Gazebo 2.2.3.
Do you know what the problem might be? Thank you.
Asked by janbed on 2016-04-26 01:26:07 UTC
Not a solution, just noting that Gazebo 2.2.3 is very old... I don't think those were ever meant to work that way. If you want a specific pose, you can specify it in the world model, or use
gz model
` to spawn a model in a specific positionAsked by Peter Mitrano on 2016-04-26 02:17:45 UTC
You are right, it is old, I am using Gazebo 2.2.3 only because it comes with ROS Indigo which I need to use. All right, I will tryto specify the pose in the world model, thank you.
Asked by janbed on 2016-04-26 02:34:49 UTC
