problems connecting to model database
I'm using gazebo simulator on Ubuntu 14.04.4. I'm having problem to connect to the model database.
while I run gazebo I get the following errors:
Warning [ModelDatabase.cc:334] Getting models from[http://gazebosim.org/models/]. This may take a few seconds.
Error [ModelDatabase.cc:228] No tag in the model database database.config found here[http://gazebosim.org/models/]
Error [ModelDatabase.cc:287] Unable to download model manifests
Error [ModelDatabase.cc:407] Unable to download model[model://sun]
Error [SystemPaths.cc:367] File or path does not exist[""]
Error [parser.cc:523] Unable to find uri[model://sun]
Msg Publicized address: 10.0.2.15
Error [ModelDatabase.cc:407] Unable to download model[model://ground_plane] Error [SystemPaths.cc:367] File or path does not exist[""]
Error [parser.cc:523] Unable to find uri[model://ground_plane] [ INFO] [1462749167.054486531, 0.024000000]: waitForService: Service [/gazebo/set_physics_properties] is now available. [ INFO] [1462749167.150879357, 0.095000000]: Physics dynamic reconfigure ready.
I tried looking up for the errors but I got no helpful answer.
In the "Insert" tab I see "conneting to model database..."
Asked by oshkosh on 2016-05-08 18:30:18 UTC
This might be the same problem as in this question: http://answers.gazebosim.org/question/13234/no-database-tag-in-the-model-database/
Asked by chapulina on 2016-05-09 10:30:53 UTC
