Has anyone ever used KDL and kdl_parser?
Hi all,
I'm trying to extrapolate the jacobian and the matrix for the dynamic form of my arm. The arm is in .xacro file, so I tried to follow this tutorial for kdlparser and this for KDL. But I've some difficulties, I'm not able to understand how to usr kdlparser. The arm is in a catkinws directory, so can I use an external C++ code or I have to use kdl and kdlparser function in my plugin? What have I to modify in CMakeList and package.xml? (are this two file owned to catkinws or to myarm directory?)
Is there someone who has already use kdl that can help me?
Thank you!
Asked by gabri89 on 2016-05-18 04:12:30 UTC
Hey Gabri89,
I used KDL a few years ago to solve some inverse calculations. But this only on the ROS side and I guess you want to do that also, referring that you are using the catkin_ws...? In that case I would recommend you to read the catkin tutorial to understand how to include dependencies.
For an approach what should be modified: Link to similar problem
But to answer your main question, the kdl_parser is meant to translate your robot model definition file (urdf) into a kdl tree. This enables kdl to see the robot model as an kinematic chain what is required.
Here is some sample where I used pykdlutils (python). Think in C++ it should look similar: Sample code
Hope it helps you.
Asked by TwoBid on 2016-05-18 08:52:58 UTC
Hi TwoBid, thank you for your answer. Yes I referred to the ROS side. I tried to follow your link for modify dependencies in CmakeList and package of my_robot. Then I tried to make a C++ code link in the example in the kdl_parser tutorial and I've this error : undefined reference to "KDL::Tree::Tree(std::string const&)" ; another error : undefined reference to "kdl_parser::treeFromFile(...)" . Where am I wrong? Thank you!
Asked by gabri89 on 2016-05-18 10:34:52 UTC
Then it's still a problem that your not including your dependencies in the right way or your dependencies does not exist or you have spelling mistake or the package has a different name.
Asked by TwoBid on 2016-05-19 01:31:45 UTC
I try to explain better. I've an arm in gazebo, in the .xacro format. I want to extrapolate the jacobian and some other matrix of this arm using KDL, but I'm not still able to do this. I'm not sure to have installed KDL correctly. If I've KDL, have I to do a c++ file in my catkin_ws? Is there a template to follow? Thank you
Asked by gabri89 on 2016-06-02 04:28:07 UTC
Easy approach for me was to use parameter server in a launch file
<param name="robot_description" command="$(find xacro)/xacro.py $(find walking_excavator_urdf)/xacro_manzi/walking_excavator.urdf.xacro" />
<node name="spawn_urdf" pkg="gazebo_ros" type="spawn_model" args="-param robot_description -urdf -x 0 -y 0 -z 1 -model robot" />
so from xacro/urdf you can directly load in ROS parameter, then use c++ code..
ros::NodeHandle node;
std::string robot_desc_string;
node.param("robot_description", robot_desc_string, std::string());
if (!kdl_parser::treeFromString(robot_desc_string, my_tree)){
ROS_ERROR("Failed to construct kdl tree");
return false;
This way you can get the tree, can verify with
unsigned int nj = my_tree.getNrOfJoints();
unsigned int js = my_tree.getNrOfSegments();
ROS_INFO("NrOfJoints =%d || NrOfSegments= %d \n", nj,js);
Asked by Nurul Karim on 2018-11-06 08:36:18 UTC
