SDF include non static model inside a static model
Hello everybody,
As said in the title, I want to include a non static model inside a static model. I want to avoid collision between the two model's links. That's why I want to use the include tag in the model.
So I have my "main" model which is representing a building's floor and some models which are representing elevators.
I tried to use static tag inside the include but it kills performance (real time factor is 0.9 when static is not used and 0.08 when I set a static tag with a 0 value).
I also tried collide_bitmask tag but it also kills performance.
So I tried to unset static in the plugin I made to control the doors. (SetStatic(false)) But it doesn't work.
Is there another way to do that ?
Update : collide_bitmask seems to have no impact on performance. Performance problem seems to be due to the location where I make the include of the elevators models.
Include in world file :
- Bad performance
- Doors can be moved
Include in the main model :
- Good performance
- Doors can't be moved because the main model is static
Thanks in advance
Asked by Brosseau.F on 2016-05-19 08:26:52 UTC
Do you want the building to collide with other models? Otherwise you could just remove all of its collision shapes :)
Asked by chapulina on 2016-05-19 11:18:52 UTC
Yes I want the building to collide with other models.
But I can probably disable collision for walls in contact with the elevator models.
Asked by Brosseau.F on 2016-05-20 01:40:38 UTC
