Gazebo impossible to install??
Ok so this is my first forum post here, I'm having alot of trouble getting Gazebo to launch.
My computer is pretty junky: Dell Latitude D520; Intel Centrino @ 1.66 GHz, 1 GB RAM. I have installed Gazebo, but it will not launch. When I type "gazebo" into terminal, one of two things will happen:
  1. I get this:
    X Error of failed request: BadDrawable (invalid Pixmap or Window parameter) Major opcode of failed request: 154 (DRI2) Minor opcode of failed request: 3 (DRI2CreateDrawable) Resource id in failed request: 0x3e00002 Serial number of failed request: 31 Current serial number in output stream: 33 X Error of failed request: BadDrawable (invalid Pixmap or Window parameter) Major opcode of failed request: 154 (DRI2) Minor opcode of failed request: 3 (DRI2CreateDrawable) Resource id in failed request: 0x4000002 Serial number of failed request: 31 Current serial number in output stream: 33
  2. Literally Nothing happens. Like: nothing runs, no output to terminal, no windows open, not even a crash window. It looks like this:
    icepaka89@icepaka89-Latitude-D520:~$ gazebo
There is barely even a delay before it goes to a new line. Clearly from the errors i do get, it's something to do with my graphics card, but I'm not quite sure what... Can anyone help me out here?? Thanks!
Asked by icepaka89 on 2016-05-31 14:36:16 UTC
You can run gazebo in verbose mode to get more output: $ gazebo --verbose. Based on your computer's specs, I doubt you'll get gazebo to run. You might be able to run the server (no gui) portion of gazebo using $ gazserver --verbose
Asked by nkoenig on 2016-05-31 17:37:33 UTC
what GPU are you using? If you have Radeon GPU, in my experience only proprietary fglrx drivers work.
Asked by hsu on 2016-05-31 17:51:22 UTC
repeating what @nkoenig says about
gazebo --verbose
also, the BadDrawable error is usually seen with unsupported GPU. If that's the cause, you can only run headless. To force headless mode, unset the DISPLAY environment variable then run gzserver with verbose flag:
$ unset DISPLAY
$ gzserver --verbose
Gazebo multi-robot simulator, version 7.1.0
Copyright (C) 2012-2016 Open Source Robotics Foundation.
http://gazebosim.org
[Msg] Waiting for master.
[Msg] Publicized address: 172.23.1.164
[Err] [RenderEngine.cc:699] Can't open display:
[Wrn] [RenderEngine.cc:97] Unable to create X window. Rendering will be disabled
[Wrn] [RenderEngine.cc:301] Cannot initialize render engine since render path type is NONE. Ignore this warning ifrendering has been turned off on purpose.
gazebo should be running but without any rendering capabilities enabled. You can open a different terminal and run gz stats to confirm and check performance, for example:
$ gz stats
Factor[1.00] SimTime[5.67] RealTime[5.70] Paused[F]
Factor[1.00] SimTime[5.88] RealTime[5.90] Paused[F]
Factor[1.00] SimTime[6.07] RealTime[6.10] Paused[F]
Asked by hsu on 2016-05-31 17:49:19 UTC
