STRANGE ERROR! Unable to move Revolute Joints in Gazebo
I'm running : 1. ROS Indigo 2. Ubuntu 14.04 Trusty
I'm simulating a 6DOF robotic arm using roscontrol and using gazeboros_control plugins. I'm using Joint Position Controllers.
I have set up the .yaml file containing the type of controllers. I have also added all the transmission and gazeboroscontrol tags in my URDF file.
Everything launches without any error. When I try to publish messages on
/nymble_arm/joint2_position_controller/command std_msgs/Float64 1.0
This is my rostopic list.
/clock
/gazebo/link_states
/gazebo/model_states
/gazebo/parameter_descriptions
/gazebo/parameter_updates
/gazebo/set_link_state
/gazebo/set_model_state
/nymble_arm/joint1_position_controller/command
/nymble_arm/joint3_position_controller/command
/nymble_arm/joint4_position_controller/command
/nymble_arm/joint5_position_controller/command
/nymble_arm/joint6_position_controller/command
/nymble_arm/joint_states
/rosout
/rosout_agg
/tf
/tf_static
I'm unable to move the revolute joints. Interestingly I have two continuous joints among my 6DOF which move.
When I publish a message on revolute joints nothing happens.
rohin@dreamworks:~$ rostopic pub /nymble_arm/joint2_position_controller/command std_msgs/Float64 1.0
publishing and latching message. Press ctrl-C to terminate
Also these movements are abrupt and not in a smooth manner. Whereas I've tried tutorials where the arm follows a smoother motion using Joint Position Controllers.
How should I get my revolute joints to move? Please help!
edit
Asked by rohin on 2016-06-06 23:17:28 UTC
