Hi I have problems installing Gazebo in Windows
cd ..\..\sdformat
# if you want debug, run ..\configure Debug
..\configure
When I use ..\configure I get the following error:
image description
Asked by nmahabadi on 2016-06-08 09:11:20 UTC
Your comment implies your error is in the sdformat step, but your screenshot shows the gazebo step. Please update your text to say the right step.
Asked by Peter Mitrano on 2016-06-08 22:59:13 UTC
The specific error is one I haven't encountered, and I do most of the windows development for gazebo. Did you install any other version of protobuf at any point?
Asked by Peter Mitrano on 2016-06-08 23:35:14 UTC
(Deleted previous convoluted answer)
Try creating a new directory called x64 under gz-ws\protobuf-2.6.0-win64-vc12\vsprojects and then copy the Debug and Release directories to it.
The FindProtobuf.cmake mdoule in cmake v3.5.2 looks in the x64 directory instead of directly in the vsprojects directory.
Asked by azaclauson on 2016-06-09 07:24:50 UTC
note ONLY do this if you are absolutely sure that CMAKE_SIZEOF_VOID_P is defined as 8. you can check that with message("\n\n size: ${CMAKE_SIZEOF_VOID_P}\n\n") Look in FindProtobuf.cmake for explanation of why
Asked by Peter Mitrano on 2016-06-14 10:36:12 UTC
Hi thanks for the reply! You are right I meant to built gazebo:
cd ....\gazebo mkdir build cd build
..\configure nmake gzclient nmake gzserver nmake install
I tried the work around you suggested, (I downloaded protobuf-2.6.0-win64-vc12) and set the path in the config file. image description
now I get the following error (missing Protobuf Compilor):
image description
Any idea?
Asked by nmahabadi on 2016-06-10 04:20:13 UTC
Check that you have downloaded all the protobuf dependencies, and that they have correct paths.
Asked by nkoenig on 2016-06-10 11:07:59 UTC
it is shockingly possible that using "D:" instead of "C:" may cause a problem at some point. Just warning you. Although I don't think that's relevant here. I dig into the FindProtobuf.cmake file that should be on your system somewhere
Asked by Peter Mitrano on 2016-06-11 23:11:01 UTC
