dependency issues with gzweb
Gzweb seems to be relatively undocumented and the issue tracker on bitbucket didn't solve my problem, which is why I'm also posting my question here after opening and issue https://bitbucket.org/osrf/gzweb/issues/80/gzweb-compitabilty-problems-with-gazebo-6
Gazebo 6 and 7 do not work with gzweb. Google chrome dev tools show an connection error with roslib, I couldn't find any more detail on the reason of that error. I've tested this on multiple machines and would like to know if anyone else has this problem and, cherry on top, a solution.
Cheers & thanks for your help!
Update: I'm talking about this git repo of gzweb: https://bitbucket.org/osrf/gzweb To be precise, I'm running gazebo 6.6.0 running on trusty right now.
Asked by deltec on 2016-06-19 13:48:59 UTC
In case you didn't see the comment in the issue, can you describe the steps you're taking to run GzWeb? Are you sure you're running gzserver first and then ./start_gzweb.sh? Can you add to the question the exact error you're getting on the console?
Asked by chapulina on 2016-06-21 10:46:09 UTC
