Picking up a soft ball using dual arm
I am trying to pick a soft ball using two arms and then throw it. I am using a soft ball because I want to be able to throw the ball even when it is slightly crushed by the fingers.
But when I try to run it using gazebo, the ball jumps around on contact. I tried making the object soft using different values of kp, kd, soft_cfm and soft_erp with no success. Any suggestions on how I can achieve this.
ball.sdf
<model name="basketball">
    <static>false</static>
    <link name="ball">
        <mass>0.25</mass>
        <!-- inertia based on solid sphere 2/5 mr^2 -->
          <ixx>0.00169</ixx>
          <iyy>0.00169</iyy>
          <izz>0.00169</izz>
          <sphere>
            <!-- <radius>0.1172</radius> -->
            <radius>0.13</radius>
          </sphere>
          <sphere>
          </sphere>
finger.sdf
<model name="finger">
  <joint name="asdf" type="fixed">
    <parent link="world"/>
    <child link="finger_link"/>
    <pose frame="">0 0 0 0 1.5707963267948966 0</pose>
  <link name="finger_link">
    <visual name='visual'>
      <pose frame="">0 0 0 1.5707963267948966 0 0</pose>
        <mesh><uri>model://finger/finger.stl</uri></mesh>
      <material name="white"/>
      <pose frame="">0 0 0 0 0 0</pose>
      <mass value="0.250"/>
      <inertia ixx="0.0" ixy="0.0" ixz="0.0" iyy="0.0" iyz="0.0" izz="0.0"/>
image description
Just before the contact between the fingers and the ball image description
Collision model
image description
Asked by lonewolf on 2016-06-19 23:44:14 UTC
Without diving in deeper into dynamics, I noticed that finger inertias have zero MOI, this is a specialized case that we have not explored much in gazebo. Can you assign realistic finger inertia complete with finite MOI?
Asked by hsu on 2016-06-22 13:08:34 UTC
please provide example complete with kp, kd, soft_cfm and soft_erp.
Asked by hsu on 2016-06-22 13:09:33 UTC
@hsu I modeled the fingers as a box and set the inertia of the diagonal to Ixx=0.0008125 Iyy=Izz=0.001125. But that did not help. I am not sure about the cfm and kp values. I used random set of values. Few that I tried are kd=1, kp=1000, cfm=erp=1. But then the ball goes through the cylinder.
Asked by lonewolf on 2016-06-22 14:37:13 UTC
@hsu Do you have any thoughts on how I could accomplish this.. thanks
Asked by lonewolf on 2016-06-27 16:06:34 UTC
