kobuki base keeps shaking in gazebo > v2
Whatever I try, my kobuki base keeps shaking, also often referred as "wobbling" behavior in gazebo > 2
Video: https://youtu.be/aBOjJyfX10M
My environment (where I want it to work)
ROS Indigo + osrf rosgazebo5pkgs + kobuki(from source)
Where it works: ROS Indigo either x32/x64 with gazebo2 (same sources of kobuki - just recompile..)
Where it doesn't work: ROS + gazebo > v2
Where I tried: ROS Jade + gazebo5 ROS Indigo x32/x64 + gazebo4/gazebo5
manual compile:
- gazebo7 -> no compile (too many errors to fix)
- gazebo6 -> no compile (too many errors to fix)
- gazebo5 -> compiles
- gazebo4 -> compiles
Fixes tried:
I found and tried several solutions, most point to the deprecated velocity /force commands.:
change / remove the velocity command. http://answers.gazebosim.org/question/8371/kobukiturtlebot-doesnt-move-when-given-velocity-commands-in-gazebo-5/
also mentioned maxforce https://bitbucket.org/osrf/gazebo/commits/0a08678cadde3fc3594fcdef777df8ea9b12c29c?at=restoremax_force5
more confusion about max_force or fmax http://answers.gazebosim.org/question/8458/setmaxforce-deprecated-in-gazebo-50/
suggests fmax right https://github.com/ros-simulation/gazebo_ros_pkgs/blob/jade-devel/gazebo_plugins/src/gazebo_ros_diff_drive.cpp
suggests max_force right https://bitbucket.org/osrf/gazebo/src/406e1297bb41cabc090c26db1642e5bbdd0b5479/plugins/SkidSteerDrivePlugin.cc?fileviewer=file-view-default
For me its currently unclear what's correct fmax or max_force however just commenting out should also work.
The problem in Code:
// deprecated
joints_[LEFT]->SetVelocity(0, wheel_speed_cmd_[LEFT] / (wheel_diam_ / 2.0));
joints_[RIGHT]->SetVelocity(0, wheel_speed_cmd_[RIGHT] / (wheel_diam_ / 2.0));
// some suggest just comment SetMaxForce (the following)
joints_[LEFT]->SetMaxForce(0, torque_);
joints_[RIGHT]->SetMaxForce(0, torque_);
// some suggest this as alternative code to SetMaxForce, but max_force seems wrong, it should be fmax
joints_[LEFT]->SetParam("max_force",0, torque_);
joints_[RIGHT]->SetParam("max_force",0, torque_);
// my best solution (that still didnt work)
joints_[LEFT]->SetParam("vel",0, wheel_speed_cmd_[LEFT] / (wheel_diam_ / 2.0));
joints_[RIGHT]->SetParam("vel",0, wheel_speed_cmd_[RIGHT] / (wheel_diam_ / 2.0));
joints_[LEFT]->SetParam("fmax",0, torque_);
joints_[RIGHT]->SetParam("fmax",0, torque_);
Summary:
I tried various versions of this.. including just commenting everything. Yes I cleaned and recompiled everytime..
Note: Without Gravity -> no problems, but.. no gravity is not a solution
So what could also happen? damper? weight? I played with kp,kd,mu1/2, mass, inertia nothing helped.
Others had the same issue and for them it worked.. https://github.com/mayfieldrobotics/kobuki_desktop/commit/4246c6e4330f39725df3eb39a0b77a7fcc6185b1 from forum http://answers.ros.org/question/209126/kobuki-strange-behaviour-in-gazebo/ and even used for a "jade" branch https://github.com/yujinrobot/kobuki_desktop/issues/41 its officially applied..
but its not working (for me)
according to Javier it should work in gazebo4
I have tested the same code in Gazebo4.1.3 and it works like a charm, so it is a Gazebo5 problem. Javier V. Gómez (May 13 '15)
From http://answers.ros.org/question/209126/kobuki-strange-behaviour-in-gazebo/
I tried, it didn’t.. (for me..)
-> the error happens already in gazebo4
something in the migration from gazebo2 to gazebo4?
migration https://bitbucket.org/osrf/gazebo/src/5adf274c0172e4707ac86523c3aedd3d332f3c7c/Migration.md?fileviewer=file-view-default and changelog https://bitbucket.org/osrf/gazebo/src/default/Changelog.md?fileviewer=file-view-default
PS: Yes I also tested the execution of my changes by messaging the ROSINFOSTREAM
what magic ingredient am I missing?
Asked by m4k on 2016-06-23 13:11:20 UTC
There might be a solution for kinetic:
https://github.com/rohbotics/kobuki_desktop/tree/kinetic
Asked by m4k on 2016-08-12 12:13:15 UTC
