[Buoyancy Plugin] Possible bug
asked 2016-06-28 12:01:44 -0500
Marco gravatar image
Hi everybody,
I'm using Gazebo 6.6.0 with Ubuntu 14.04 and currently I'm experiencing strange behaviors with the buoyancy plugin shipped with this version.
The following minimal working example shows two sphere, of mass 1 kg, and the usage of the buoyancy plugin where I force the volume of these two sphere to be equal to their mass. Having fluid density equal to 1 should result having the two objects floating in the air, because in this case force_of_gravity == force_of_buoyancy. Unfortunately only the first sphere, l1, floats whereas the second one falls down.
<?xml version='1.0'?>
<sdf version='1.5'>
<model name="buoyancy_example">
  <!-- ================== link l1 ================== -->
  <link name="l1">
    <pose>0 0 1 0 0 0</pose>
    <inertial> <mass>1</mass> </inertial>
    <visual name='visual'>
          <sphere> <radius>0.5</radius> </sphere>
    <collision name='collision'>
  <!-- ================== link l2 ================== -->
  <link name="l2">
    <pose>2 0 1 0 0 0</pose>
  <!-- ================== buoyancy plugin ================== -->
  <plugin name="buoyancy" filename="libBuoyancyPlugin.so">
    <fluid_density>1</fluid_density>
    <link name="l1">
      <center_of_volume>0 0 0</center_of_volume>
      <volume>1</volume> <!-- volume == mass ==> object should float -->
    <link name="l2">
image description
Based on my trials I believe that the problem is in this for statement here, which doesn't return the next link element within the plugin tag. Does anyone know how I can fix this bug and be able to use multiple "links" tags within this plugin?
Thanks,
Marco.
answered 2016-06-28 12:07:20 -0500
chapulina gravatar image
updated 2016-06-29 11:07:05 -0500
It looks like a bug. That statement you mentioned should be:
linkElem = linkElem->GetNextElement("link")
It would be great if you could make a pull request to Gazebo with the fix, and a bonus if you add a test with your use case. The pull request could be targeted at branch gazebo6.
Hi, I just checked your suggest and now the plugin works ... thanks :) I'll make the pull request, but I'm not totally sure about how to write a test for it ... could you give me more information about how to do it? Thanks
Marco gravatar imageMarco ( 2016-06-29 02:35:34 -0500 )edit
Oh I wouldn't worry too much about the test, it would just be a bonus ;) It would probably involve writing an integration test: https://bitbucket.org/osrf/gazebo/src/default/test/integration/
chapulina gravatar imagechapulina ( 2016-06-29 11:05:51 -0500 )edit
ok, I created a pull request targeted to gazebo6. About the test: I'm not totally sure about how to check if the plugin is working well. Should I spawn two objects and check if the heights of their centers of gravity are > 0 ?
Marco gravatar imageMarco ( 2016-06-30 01:50:57 -0500 )edit
Thanks! Sounds good. Make sure to let enough iterations pass so the models have time to float.
chapulina gravatar imagechapulina ( 2016-06-30 09:22:34 -0500 )edit
The pull request with the fix has been merged by the way ;) You're still welcome to add a test, it will make sure we don't break this in the future by mistake.
chapulina gravatar imagechapulina ( 2016-06-30 12:24:44 -0500 )edit
cool! I'll try to write a simple test in the next days ;)
Marco gravatar imageMarco ( 2016-07-01 01:39:39 -0500 )edit
Asked: 2016-06-28 12:01:44 -0500
Seen: 560 times
Last updated: Jun 29 '16
