Interaction between 2 objects in Gazebo
I am working on a "pick and do" operation in ROS and simulating the same in Gazebo. I have model of a wrench, which is attached to my own gripper in URDF. The gripper in turn is attached to UR5. This setup has to rotate a knob on a panel. But as soon as the gripper touches the knob, the panel flies off even though the mass of the panel has been defined as 800kg in the sdf file. https://youtu.be/7vpE6pHe0x8
I tried the same setup by replacing my gripper with PR2 gripper (and without the wrench) and I getting decent results. So my guess is, again there seems to be some problem with the inertia of my gripper and the wrench. Would be great if anyone could help me in defining it correctly. Remove the .jpg at the end of the file name. C:\fakepath\gripper.stl.jpg
Gripper urdf : C:\fakepath\gripper.urdf.xacro.jpg
Panel sdf : C:\fakepath\model.sdf.jpg
Here's the video after making the panel model static. https://youtu.be/eP29QGYoQhY
Asked by intelharsh on 2016-07-05 04:47:59 UTC
Have you tried visualizing the inertia on Gazebo? Right-click the model and choose View->Inertia and View->CoM. Then tweak the inertia values until you get a better approximation to your shape.
Asked by chapulina on 2016-07-05 10:44:12 UTC
I am using the inertia of a cuboid macro. So I am not sure if I can make any changes apart from the mass.
Asked by intelharsh on 2016-07-06 00:35:16 UTC
The problem disappears after I enable
kinematic
property in Gazebo GUI for each link of UR5. Also, I can't do this withThe only property which changes is
selfCollide
. How can I change this through URDF? I haven't found any documentation. I could save the world file with the entire setup. Can I load the world file instead of URDF for UR5 as well?Asked by intelharsh on 2016-07-06 00:41:17 UTC
