Trouble With The Animated Model (Actor) Tutorial
Hi all, I'm relatively new to Gazebo, but have worked some of the tutorials and have a basic understanding of the software.
I'm trying to work through the "Make An Animated Model (Actor)" tutorial and am having some trouble.
I'm running Gazebo 7 on Ubuntu 14.04 (LTS). I'm trying to replicate the animated box moving through waypoints like the tutorial demonstrates, but it's not working for me. I'm following the steps exactly as listed in the tutorial, but when I load the "animated_box.world" into Gazebo all I get is a world with nothing in it. There is a ground plane model and light, but no box.
I have saved the animatedbox.world file from bitbucket into a "worlds" directory on my system (/home/gazebo7/worlds). If I then go to a terminal and enter "gazebo ~/gazebo7/worlds/animatedbox.world", Gazebo will load with a ground plane and light.
What am I missing? Are there implied steps in the tutorial that I am missing (not seeing)? Should there be a box model in a model directory that the world file is looking for? I don't see an "INCLUDE URI model:// tag anywhere. Should there be one?
I'm wondering if the tutorial is from an older version of Gazebo since the text says "Let's take a look at a simple example world which comes with Gazebo:". There is no "animatedbox.world" on my system in "/usr/share/gazebo7" (or anywhere else except what I have downloaded from bitbucket).
Any help would be greatly appreciated! It can't be that hard, but obviously I'm missing something.
Thanks!
Asked by mikec on 2016-07-13 12:10:02 UTC
If you notice the box on the top right side of the tutorial, that tutorial applies to Gazebo 8, which has not been officially released yet. To use these features right now, you'd need to install the nightly builds, but beware they are unstable. Otherwise, you'll need to wait until the release on January 2017.
This should be clearer, many people miss the version box on the right. I'll add a big note in the beginning of the tutorial.
Asked by chapulina on 2016-07-13 12:40:16 UTC
An obvious oversight on my part. Thanks for pointing that out.
Asked by mikec on 2016-07-13 14:00:05 UTC
It works. Sweet! Thank you!!
Asked by mikec on 2016-07-13 16:28:12 UTC
