What is the default effort applied in case of Joint_effort_controller?
I saw in a web forum that there are three options for effort_controllers
effortcontrollers 1)jointeffortcontroller 2) jointpositioncontroller 3) jointvelocity_controller
in case of (2) the jointpositioncontroller it seems that the default position is the position of the description of the robot. So if we select jointeffortcontroller, what would the default effort that will be applied to the joints and , is it possible to specify these initial controller inputs in the launch files?
Asked by Abdullah on 2016-07-13 16:18:05 UTC
You can specify any controller with a yaml file, and set the path of it in a launch file.
Asked by itfanr on 2018-10-08 00:46:12 UTC
