inertias not work well in my model
I'm triying to make a Formula 1 (with two cameras and a laser) model, but when I put inertias in the model, they not work. I`m using gazebo7.
We have a client that connects to a plugin we have made for gazebo and allowing drive the F1 through a circuit.
we use the same motors plugin to teleoperate turtlebot founds in gazebo oficial model repository and works well. By that y think that this problem is with intertial values.
To create the intertial matrix, I used this manual: http://www.gazebosim.org/tutorials?tut=inertia&cat=build_robot.
when I accelerated the formula 1 to some 27 m/s and then I give a value 0 of speed, braking in dry. the speed becomes zero at that moment without seeing as it advances a little while it slows down.
Meshlab values:
Mesh Bounding Box Size 0.401645 0.888804 0.204933 Mesh Bounding Box Diag 0.996639 Mesh Volume is 0.020711 Mesh Surface is 3.429925 Thin shell barycenter -0.002349 0.296365 0.058029 Center of Mass is -0.003402 0.372718 0.070094 Inertia Tensor is : | 0.000232 -0.000002 -0.000000 | | -0.000002 0.000124 0.000104 | | -0.000000 0.000104 0.000340 | Principal axes are : | -0.015143 -0.926820 0.375202 | | 0.999861 -0.011424 0.012136 | | -0.006961 0.375333 0.926864 | axis momenta are : | 0.000082 0.000232 0.000382 |
Asked by aitormf on 2016-07-19 04:22:40 UTC
Can you add more information about you problem?
Asked by nkoenig on 2016-07-19 09:23:21 UTC
I edited it with more information
Asked by aitormf on 2016-07-20 03:02:47 UTC
