Diff_drive Plugin Simulation Problem
Hi, I have written a urdf file for a 2 wheeled robot, but I can't seem to get it to drive properly using the diffdrivecontroller gazebo plugin. Instead of driving normally, the robot somersaults in the direction that I want it to move in. Is there anything I'm doing wrong when I'm setting the conditions of the plugin? I'm new to ROS.
<?xml version="1.0"?>
<robot name="crobot">
<link name="base_link">
<visual>
<box size="0.100 0.110 0.131"/>
<origin xyz="0 0 0.0805"/>
<collision>
<mass value="1"/>
<inertia ixx="1.0" ixy="0.0" ixz="0.0" iyy="1.0" iyz="0.0" izz="1.0"/>
<link name="basecenter1">
<visual>
<box size="0.10 0.34 0.131"/>
<collision>
<mass value="0.1"/>
<link name="basecenter2">
<visual>
<box size="0.330 0.110 0.131"/>
<collision>
<mass value="0.1"/>
<link name="blcorner">
<visual>
<cylinder length="0.131" radius=".12"/>
<collision>
<mass value="1"/>
<link name="brcorner">
<visual>
<collision>
<mass value="1"/>
<link name="flcorner">
<visual>
<cylinder length="0.131" radius=".11"/>
<collision>
<mass value="1"/>
<link name="frcorner">
<visual>
<collision>
<mass value="1"/>
<link name="lwheel">
<visual>
<cylinder length="0.018" radius="0.0325"/>
<origin rpy="0 1.570796 0" xyz="0 0 0"/>
<material name="blue">
<color rgba="0 0 .8 1"/>
<collision>
<!--radius="0.0325"-->
<mass value="0.5"/>
<gazebo>
<selfCollide>false</selfCollide>
<link name="rwheel">
<visual>
<collision>
<mass value="0.5"/>
<gazebo>
<joint name="base_lwheel" type="continuous">
<parent link="base_link"/>
<child link="lwheel"/>
<origin xyz="-0.130 0 0.0325" rpy="-1.570796 0 0"/>
<joint name="base_rwheel" type="continuous">
<child link="rwheel"/>
<origin xyz="0.130 0 0.0325" rpy="-1.570796 0 0"/>
<joint name="base_basecenter1" type="fixed">
<child link="basecenter1"/>
<origin xyz="0 -0.005 0"/>
<joint name="base_basecenter2" type="fixed">
<child link="basecenter2"/>
<origin xyz="0 0 0"/>
<joint name="base_blcorner" type="fixed">
<child link="blcorner"/>
<origin xyz="-0.05 -0.055 0"/>
<joint name="base_brcorner" type="fixed">
<child link="brcorner"/>
<origin xyz="0.05 -0.055 0"/>
<joint name="base_flcorner" type="fixed">
<child link="flcorner"/>
<origin xyz="-0.05 0.055 0"/>
<joint name="base_frcorner" type="fixed">
<child link="frcorner"/>
<origin xyz="0.05 0.055 0"/>
<gazebo>
<plugin name="diff_drive_controller" filename="libgazebo_ros_diff_drive.so">
<rosDebugLevel>false</rosDebugLevel>
<alwaysOn>true</alwaysOn>
<publishWheelJointState>true</publishWheelJointState>
<updateRate>100.0</updateRate>
<leftJoint>base_lwheel</leftJoint>
<rightJoint>base_rwheel</rightJoint>
<wheelSeparation>0.26</wheelSeparation>
<wheelDiameter>0.065</wheelDiameter>
<wheelAcceleration>1</wheelAcceleration>
<wheelTorque>20</wheelTorque>
Asked by Lunescense on 2016-07-19 21:48:47 UTC
Check your inertia values, collision shapes, and joints. Also try reducing (or otherwise alternating) wheel torque.
Asked by nkoenig on 2016-07-20 13:14:24 UTC
