Setting contact coefficients
We have designed our own magnetic gripper for a pick and place application. I was successfully able to import this and visualize the inertias in Gazebo.
But when I visualize the contacts, the vector keeps on moving frantically. Even though the movements of the arm itself is very smooth, when it comes in contact with another object, it starts vibrating. https://youtu.be/eP29QGYoQhY
I dug into PR2 gripper because it behaves very realistically when it is in contact with other objects and tried to implement the contact coefficients
Attempt 1 :
<surface>
<friction>
<ode>
<mu>0.01</mu>
<mu2>0.01</mu2>
<fdir1>0 0 1</fdir1>
<slip1>0.0</slip1>
<slip2>0.0</slip2>
</ode>
</friction>
<contact>
<ode>
<min_depth>0.005</min_depth>
<kp>1e8</kp>
</ode>
</contact>
</surface>
Attempt 2 : This is exactly like the PR2 gripper
<gazebo reference="gripper_link">
<selfCollide>false</selfCollide>
<mu1 value="${finger_tip_mu}" />
<mu2 value="${finger_tip_mu}" />
<kp value="10000000.0" />
<kd value="1.0" />
<gazebo reference="gripper_joint">
<stopKd value="${finger_stop_kd}" />
<stopKp value="${finger_stop_kp}" />
<fudgeFactor value="${finger_fudge_factor}" />
<provideFeedback value="true"/>
This is my entire gripper xacro file :
<?xml version="1.0"?>
<robot xmlns:xacro="http://www.ros.org/wiki/xacro">
<xacro:macro name="gripper_link" >
<link name="gripper">
<mass value="0.6" />
<origin xyz="-0.02 0 0.04" />
<inertia ixx="0.0003" ixy="0.0" ixz="0.0"
iyy="0.0009" iyz="0.0"
izz="0.0008"/>
<visual>
<mesh filename="package://ur5_pnp/meshes/gripper.stl" scale="0.01 0.01 0.01"/>
<collision>
<surface>
<friction>
<ode>
<mu>0.01</mu>
<mu2>0.01</mu2>
<slip1>0.0</slip1>
<slip2>0.0</slip2>
</ode>
</friction>
<contact>
<ode>
<min_depth>5</min_depth>
<kp>1e8</kp>
</ode>
</contact>
</surface>
<gazebo reference="my_gripper">
</xacro:macro>
</robot>
But both the times I get the exact same behaviour. Is it something to do with friction or is it some other issue? This is my gripper's stl file
Edit 1: This gripper has no moving parts which is to simulate a magnetic gripper.
Edit 2: Updated link for STL file
Asked by intelharsh on 2016-07-25 01:13:29 UTC
The problem could be related to the maximum velocity (<max_vel>
) applied to contacts.
SDF snippet:
<collision name="collision_name">
<surface>
<contact>
<ode>
<kp>1000000.000000</kp>
<kd>1.000000</kd>
<max_vel>100.000000</max_vel>
<min_depth>0.000000</min_depth>
</ode>
</contact>
</surface>
Asked by nkoenig on 2016-07-25 10:39:37 UTC
Sorry but still the same problem
Asked by intelharsh on 2016-07-26 02:46:47 UTC
The arm still passes through the object with high vibrations which sends the robot flying. Also, I just noticed that you mentioned it as SDF snippet. Can't I add this in URDF as gazebo reference
Asked by intelharsh on 2016-07-26 07:09:33 UTC
You can use gazebo reference in URDF.
Asked by nkoenig on 2016-07-27 10:01:10 UTC
Since I'm currently working on the same type problem I read through this post and your answer. Question: shouldn't max_vel be set to something smaller than the default of 0.01? You gave a value of 100 in your answer. What gives, eh?
Asked by raequin on 2018-08-08 21:14:11 UTC
I can't seem to access your stl file. Is there an alternate way for you to post it?
Asked by nkoenig on 2016-07-27 10:01:45 UTC
Your gripper xacro file is a mixture of both URDF and SDF. You can't have a
<surface>
tag in URDF.Asked by nkoenig on 2016-07-27 10:04:50 UTC
I have updated the link for the file. Is it accessible now? So is the ´Attempt 2´ correct way to define the contact / friction parameters in URDF?
Asked by intelharsh on 2016-07-28 03:38:43 UTC
Hey, there, I realize this question of your is really old but as I'm currently working on the same type problem I want to check and see if you managed a solution. Any tips to share with me?
Asked by raequin on 2018-08-08 21:12:14 UTC
