Camera Gimbal for Hector/Gazebo
Hi, I'm relativity new to gazebo and working with the hector quadrotor package (http://wiki.ros.org/hector_quadrotor). However, for a project i want to add a gimbal camera (roll, pitch,yaw) to the quadrotor. The idea is to be able to send a ros message to move the gimbal.
I'm not sure what is possible and what is the fastest way to have this:
1.Is it possible to send a tf to update the link? i was not abel to do this (nothing moved) 2. Would it be possible to publish on the jointstatepublisher topic? also there, nothing moved. 3. Do i have to actuate the joint where the camera is attached?
e.g. modify the file in the following way:
<joint name="${name}_joint" type="revolute">
<xacro:insert_block name="origin" />
<parent link="${parent}"/>
<child link="${name}_link"/>
<limit effort="300" velocity="1" lower="-2.61799387799" upper="2.6128806087" />
<dynamics damping="50" friction="1"/>
add a transmission
<transmission name="tran1">
<joint name="${name}_joint">
<hardwareInterface>PositionJointInterface</hardwareInterface>
<actuator name="motor1">
</actuator>
</transmission>
and add a gazebo control plugin:
<gazebo>
<robotNamespace>q1/</robotNamespace>
Is this more or less the correct way to do this? Or has anyone done this before? perhaps this is the right plugin: https://github.com/tu-darmstadt-ros-pkg/hector_camera_control but i can not compile it with ros indigo.
Best, Tobi
Asked by naegelit on 2016-07-26 08:11:34 UTC
Hi Tobi, I'm currently trying to achieve the very same thing as you but without the controller (I just need to camera pointing downwards the entire time). Did you get anywhere with this?
Asked by Willwill on 2017-08-14 10:32:15 UTC
