How to drawn dash lines or points on simulator?
asked 2016-07-27 23:24:35 -0600
avlara gravatar image
Hi everyone,
My main reason to use the Gazebo is to test the design of advanced control loop. For comparative visual results, I need to draw points or dash lines (or just lines) where the robot should have pass and where it actually went in running time.
  • Anyone has already done something like it?
  • What type of plugin must I create?
  • What class will help me to design this functionality?
Some examples are welcome!
answered 2016-07-28 15:27:29 -0600
This is really something better suited for RViz. It might be possible to do in gazebo, but it won't be easy or fun. The closest thing I can think of would be a visual plugin. You can see an example of using a visual plugin to change the color of a link here:
video
code
As well another more complex usage here:
video
code
But again, I encourage you to look at RViz instead, because gazebo visualization controls are incredibly crude. Simple lines or points won't be trivial and you won't find any example code
Thanks for you answer! Sorry, I didn't express well. My project is bigger than I said and, in this step, I'm using the simulator just to test control loops. But, in the future, someone will develop others features like algorithms of motion planning, maps and obstacles in the scene and so on. Besides that, we chose use ROS to communicate with other systems. Due to this, Gazebo is better than Rviz for our purpose.
avlara gravatar imageavlara ( 2016-07-29 16:47:10 -0600 )edit
Your code will help me a lot! I saw in the second example that you create boxes and their visual features in the world plugin in running time. Do you know if these boxes are statics?
avlara gravatar imageavlara ( 2016-07-29 16:47:26 -0600 )edit
Gazebo and RViz are not mutually exclusive. They should both be used together. Especially if you're using ROS. Is for my maze example, the maze itself is generated statically at run time. The dots are actually part of a separate project that you can view here: https://github.com/WPISmartmouse/2016_Solvers/blob/master/sim/SimMouse.cpp This shows how publishing visual messages can let you show primitive shapes (in this case cylinder)
Peter Mitrano gravatar imagePeter Mitrano ( 2016-07-30 00:48:07 -0600 )edit
answered 2016-07-29 16:30:18 -0600
nkoenig gravatar image
You can create a VisualPlugin. Here is an example.
I didn't know that Visual plugin exists. Where must I call the plugin? World file? Model File?
avlara gravatar imageavlara ( 2016-07-29 16:58:58 -0600 )edit
The example I posted shows a visual plugin (the first set of links). It's not well advertised and there are no tutorials so that will be your best reference
Peter Mitrano gravatar imagePeter Mitrano ( 2016-07-30 00:48:39 -0600 )edit
Asked: 2016-07-27 23:24:35 -0600
Seen: 1,691 times
Last updated: Jul 29 '16
