How to visualize laser beams in velodyne hdl-32 sensor?
asked 2016-07-29 02:01:27 -0500
Ani_robo16 gravatar image
updated 2016-07-30 08:34:33 -0500
I am trying to use velodyne hdl-32 sensor whose details are available here . I have create the world file exactly as mentioned here. But I am unable to see the laser beams.
Please let me know if anybody has idea about how to resolve it.
I use Gazebo 2.2 which is supported with ROS INDIGO. The model SDF file is given below.
<?xml version="1.0" ?>
<sdf version="1.4">
<world name="default">
<uri>model://sun</uri>
<joint type="revolute" name="joint">
<pose>0 0 -0.036785 0 0 0</pose>
<parent>base</parent>
<child>top</child>
<axis>
<xyz>0 0 1</xyz>
<limit>
<lower>-10000000000000000</lower>
<upper>10000000000000000</upper>
</limit>
</axis>
<model name="velodyne_hdl-32">
<link name="base">
<pose>0 0 0.029335 0 0 0</pose>
<mass>1.2</mass>
<ixx>0.001087473</ixx>
<iyy>0.001087473</iyy>
<izz>0.001092437</izz>
<collision name="base_collision">
<cylinder>
<radius>.04267</radius>
<length>.05867</length>
</cylinder>
<visual name="base_visual">
<pose>0 0 -0.029335 0 0 0</pose>
<mesh>
<uri>model://velodyne_hdl32/meshes/velodyne_base.dae</uri>
</mesh>
<link name="top">
<pose>0 0 0.095455 0 0 0</pose>
<mass>0.1</mass>
<ixx>0.000090623</ixx>
<iyy>0.000090623</iyy>
<izz>0.000091036</izz>
<sensor type="ray" name="sensor">
<pose>0 0 -0.004645 1.5707 0 0</pose>
<ray>
<scan>
<horizontal>
<samples>32</samples>
<resolution>1</resolution>
<min_angle>-0.53529248</min_angle>
<max_angle>0.18622663</max_angle>
</horizontal>
</scan>
<range>
<min>0.05</min>
<max>70</max>
<resolution>0.02</resolution>
</range>
</ray>
<collision name="top_collision">
<cylinder>
<radius>0.04267</radius>
<length>0.07357</length>
</cylinder>
<visual name="top_visual">
<pose>0 0 -0.0376785 0 0 1.5707</pose>
<mesh>
<uri>model://velodyne_hdl32/meshes/velodyne_top.dae</uri>
</mesh>
</world>
What version of gazebo are you using? Can you post your model SDF file?
nkoenig gravatar imagenkoenig ( 2016-07-29 16:28:50 -0500 )edit
Gazebo 2 is deprecated. Try upgrading to gazebo7.
nkoenig gravatar imagenkoenig ( 2016-08-01 10:18:53 -0500 )edit
