run c++ code on Gazebo simulator
so i have this c++ code https://github.com/erlerobot/ros_erle_takeoff_land/blob/master/src/main.cpp#L21-L24
and I want to run+test it on Gazebo simulator, any idea how can I do this I have ROS indigo installed in my laptop and Gazebo 4 all under ubuntu 14.04. I'm a beginner so if can provide me with the steps that will be great :)
Thank you
Asked by Mrmrzamany on 2016-08-09 06:28:41 UTC
So you have a node that will call a service to make a robot move , am I right ?
You probably have to write a plugin that will receive the call of your service and make your robot move :
And in a launch file, you will start your node, gazebo and spawn your robot model(which will include a plugin tag with your plugin):
Asked by Brosseau.F on 2016-08-10 02:03:32 UTC
