Spline Control In Corners
Is there a way to control the spline in a corner? For example, if you run the "Animated Box" tutorial, you will notice that a 90 degree corner isn't really a "sharp" corner. There is a bit of curvature in the corner. Is there a way to make this a sharp or hard corner without the curved motion through the corner?
Thanks
Asked by mikec on 2016-08-11 11:03:42 UTC
